Hi guys.
This should be very simple for you knowledgeable types in here. I have a simple CH system on two floors with only two radiators on the ground floor fed from a single feed up above to suit our concrete floor. It's a really convenient system to work on except for one thing. The drain tap is fitted on the bottom horizontal return from one leg of a radiator at its absolute lowest point on the ground floor in a very convenient place but, when I come to use it, it leaks! When I say leaks I mean it is a constant dribble. It is sound as a bell when it is locked up and not actually in use but when I open it to release water into the hose it comes out through the correct spigot but it also dribbles out of the control screw in line with the fitting. (Hope that is clear enough. Just in case I have attached a pic showing where I mean it leaks from.)
Is this normal for a simple brass fitting of this type? I would have thought that that is the one thing a good design would have prevented so I am leaning towards it being faulty. It means that at the moment we have to drain through a hose on the outlet spigot and also constantly catch and empty the considerable amount of water which leaks from the square headed control cap at the same time.
