Drain all you can with a hose, then use a WET VAC.
And before you do any work in the lower level, check you can safely get out through a window in an emergency.
And if you're going to be using a blow lamp, a Fire extinguisher would be handy to prevent that possible emergency in the first place
Why not drain the top half like normal and the bottom half into a few buckets via a rad valve. Won't take long at all.
