blister
I intend to install the washing machine in the detached garage which has a water supply, surface water drains but no soil drain. I have exposed the 110mm kitchen soil drain (see sketch) which is approx. 6 metres from the proposed site of washing macine. I would like advice on what is the best possible options and do's and dont's. ie can I run 40mm for the whole 6 meters from the garage to the exposed drain pipe. Can I use a strap on boss to attach it, or must the whole job be done in 110mm pipe with 40mm through the garage wall. Thanks in advance
