Drayton Digistat+ 3 hard wire problem
View the thread, titled "Drayton Digistat+ 3 hard wire problem" which is posted in UK Plumbers Forums on UK Plumbers Forums.
I've connected it to the correct wires like you said. If I override the thermostat like the old programmer it would fire the boiler up but it isn't doing it on this now?
Yeah the Honeywell worked fine I only replaced it caused it looked dated. The temperature in the house ATM is 25 degree centigrade I override it to 30 the small flame appeared on the display and it should then fire the boiler up? I did read this programmer and all other thermostatic programmers that are made now have an intelligents built into it. I'm thinking because I
The house is already very warm it won't fire the boiler due to the fact that it's too warm and this must be the intelligents kicking which makes it be energy effiencency? Would I be correct?
you got a multi meter/ volt pen?
I don't sorry. I've got a neon flat head. The Honeywell worked fine. What do you think it could be? Should it just override matter what the room temperature is?
if the flame sim is there then the room stat is calling for heat pitty you didnt have a multi meter with you as red should be live (when power is on) and black is back to the boiler for call (eg turn on) i think
Should it matter if the red sleeving is biting down on the screw rather than the copper wire in the connecter block on the Drayton programmer?
the first time you did it, it should be like this
Yeah shaun I've done it that way. From your experience What could be the problem?
sorry to say hard to tell with out a multi meter if you have voltage in red one (230-250v) to earth could be the stat but if you dont have voltage on red or black could be further back, does it work with old stat back on ?
you didnt do them live did you?
do you have a heating timer on the boiler or is it sep? if you do you only need a simple room stat
Drayton Digistat + Room Thermostat | Thermostats | NoLinkingToThis
[url]http://www.NoLinkingToThis/p/honeywell-dt90e-digital-room-thermostat-eco/41365
[/URL]
Honeywell CMT921 Wireless Room Thermostat | Wireless Thermostats | NoLinkingToThis
Got it working. The face on the programmer wasn't connecting the pcb board. As I had it screw too tight against the wall. It's clicking off and off now. Great.
😀 bloody plastic cr*p
good job for sticking with it
Yeah I know. When I remove the back case and put the front back on I heard the signal wire making a click sound to the boiler then it fired up. Thanks to your patience and expert advise now I have a new programmer working.
Thanks again.
Thanks again.
not a problem
Reply to the thread, titled "Drayton Digistat+ 3 hard wire problem" which is posted in UK Plumbers Forums on Plumbers Forums.
Dave Box,
ShaunCorbs,
