View the thread, titled "Electric combi boiler for underfloor heating and rads - off the grid" which is posted in Boiler Advice Forum on UK Plumbers Forums.
serfer
Hi all,
I'm new here and trying to get my head around the selection of boilers as none of them seem to have very detailed spec sheets. My property is off the mains gas grid, with no space for LPG or oil tanks. I can't afford biomass or air source pumps which leaves me with an electric boiler.
I would like the boiler to run the underfloor system, radiators and domestic hot water for a 3 bed, 2 bath home.
I would like it to be a combi boiler.
Anyone got any ideas of a good model?
Thanks!
I have no space even to bury the tank.
Moving house use isnt really a helpful idea! I am looking for advice and assistance. I know electric combi may not be the cheapest option in terms of per unit of fuel, and I dont want to discuss running costs, refuelling, installation or servicing costs.
I am just wondering what electric combi boiler would be suited for ufh and rads and domestic hot water. 🙂
thx all
You dont want a combi. You want an unvented direct cylinder heating up on cheap rate. Thats if you have the water pressure and flow. Then you need an amptec for your underfloor and an amptec for your rads. Then big pockets to pay the leccy bill.
No. Cheap rate isnt an option for me as I have huge amounts of electric running during the day / when the rate would be much higher than usual.
I save hundreds on installation and maintenance and I have very little space so combi electric is the way to go. This much i know and i dont need to hear alternatives thx v much for the input, but i really just would like thoughts on good electric combi boilers for rads, ufh and domestic hot water!
Simon is right, serfer. Electric combi will not give you anything like the flow rate of a gas boiler. To heat UFH and rads a smallish Amptec will do the trick. Direct unvented for hot water. It's irrelevant that you use loads of electricity during the day - the cheap rate you use during the night will still save you some money. If you're really not concerned about saving money then just run the immersions 24/7.
Look at the electric heating company based in Scotland I've fitted a few of their units and they seem to be ok that said they have only ever been fitted in flats and one guy moved out 8 months later due to running costs.
To to get the heat load you need your going to need a 3 phase supply to run an average house electrics day to day plus allowance for maximum load in winter.
Personally for what your asking/adamant on doing I'd get 2/3 heatrae sadia inline boilers (tall slim pass through type) in tandem linked with an unvented hot water cylinder fed via a heavy duty water softener.
Id is also get solar panels on the roof. I know you've stated that the cost of renewables is out of your range, but you can get them free you won't earn a penny out of them like the people who own them but youll
be making a start on reducing an astronomical running cost.
And nod although you say there is no room for the alternatives, there is always a way always. How can you live of the beaten track cut off from mains gas and not have space? Equally if you are off mains gas I can't imagine you will have an overly adequate electrical supply
If this much you know why are you bothering to ask on here?
The bit you clearly don't know is the basic laws of science & the limitation of the domestic house electrical supply.
We wouldn't even be recommend that you install a gas fired combi to supply the hot water to your two bathroom house at around 30kW it would provide a very poor hot water flow & not be able to provide the heating at the same time.
Lets just say you went with an electric version.
30kW = 30,000watts / 230Volts = 130 Amps, have you checked the size of your cut out fuse on the incoming electric supply to your house, if not go take a look.
Thanks everyone for the information! Its really helpful to get pro input. I own a little cottage, for me and family to live in, with no land, out in the country off the grid. There has never been a heating system in place - just a few old wood burners.
I have been been investigating heat source and distribution since November and have resigned myself to having no option other than electric. Or 47kg bottled calor gas. I really don't have much room downstairs (trying to start running a business from home that needs equipment and loads of storage) and the loft is 350yrs old and cant take the weight of a tank up there.
Re the electrics - I have just had the PME update for my earth and I'm running 60amps until my metre gets updated when I could go to 100A. The electric hardware, cabling, sockets and all will be done entirely from new next month.
I imagine the 75sqm ufh will be running a lot. 6 Upstairs rads used sparingly if at all. Really dreading the thought of high running costs. Why is combi no good? Is it because it would always be running?
Electric is my only option but... I'm wondering why combi would be very expensive to run when compared to another electric system...
Because it take large amounts of energy to heat water instantaneously (4.186J/degC/Litre).
That 30kW gas fired combi I was talking about will deliver something like 12Litres a minute @ a 35deg C rise in Temp just enough to supply one tap properly. If we took all of your current electrical supply & used it all to heat hot water it would be equivalent to a 13.8kW combi (60Amp x 230V=13,800w).
Get the idea ?
Ever used an electric shower ? they are limited to around 10.5Kw for a reason & you don't get a good shower out of them in the winter do you.
Heating water instantly?
I was hoping to find a combi with an internal store of 50-150 litres that is kept ticking over at a good temperature...
you dont seem to be listening to anyones advice at present!!
I'm listening but i get confusing information. I am told that a communism expensive because it needs to heat water instantaneously, but then i am also told that combi boilers have a store and just need to trickle heat in to keep the store nice and hot... The advice is also conflicting about what type and number of boilers i may need too. So while I am listening, when a question mark appears based on that advice, I will follow it up as best i can. I hope rather than personal remarks we can focus
more on answering the questions raised.
Not seen any conflicting advice on this thread, you've been told countless times what you want cannot be done and why.
Have you ever heard of confirmation bias?
We do our best, free of charge to help people, there is no confusion its the laws of science as I have already stated & tried to explain.
Its not our fault you can't take what you are being told onboard & don't know what a combination boiler is.
Sorry me old fruit but I am out of here!!! :waving:
Reply to the thread, titled "Electric combi boiler for underfloor heating and rads - off the grid" which is posted in Boiler Advice Forum on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
Boiler Advice Forum
Start date
Last reply date
serfer,
tamz,
