Explosive ignition problem
View the thread, titled "Explosive ignition problem" which is posted in Central Heating Forum on UK Plumbers Forums.
B
Bhoydavid
Hi all, just noticed recently that when my boiler in the house first fires up it makes a noise which I can only describe as someone a bit away dropping an old metal bin lid on the ground. I reckon it's making such a racket due to explosive ignition but it has only started over the last couple of ideas. Anyone any ideas as to why it's sudden
doing this? Cheers
Its a potterton promac combi 33 he. Just noticed there that the front cover seems to have a dent in it that you can push in and when it fires up it 'pops' out
Depends on the boiler some times the electrodes have warped and have a weak spark allowing a little more gas into the chamber before it ignites.
Could be a vacuum issue the sudden pressure behind the ignited burner causes the case to suck its sides in in which case you have an air flow problem.
flue clamp seal perished re circulation of its own air giving incorrect mix upon start up
I've had explosive ignition on my boiler for 3yrs now. I have changed electrodes, changed spark igniter, inlet pressure great, cleaned condensate, cleand out sump and flue ways and it is still doing it. Rather annoying it is
Our lass loves it with the door off makes her feel 21 again. ..... 21 stone
(Edit) she's never been more than a size 12 so a tad unfair she's got one in the oven so forgivable
Condensate running okay?
Electrodes is first thing that springs to mind, too much gas in the camber
Got this on a customers promax ,let us know if it electrodes
The problem seems to have disappeared, anytime the boiler has fired up today it has done it without the banging noise. Strange
horrid boiler - electrodes and lead can be troublesome also check the door seals and the burner these are known to come apart and can melt the boiler
Go on!! live a little fella it's Saturday night try it out!!
Sorry feller, I wasn't brave enough to have a go. Especially on a saturday night. The wife goes nuts when ever I start stripping things at the weekends. They usually end up going from bad to worse!
Including her or just inanimate objects?
I love solo 3's and all of their potterton. / main children
No so keen on delinquent cousins "GA" family tree
So I tried it with the case off today. Still exploding! So phoned baxi, he got me to check gas valve. The 1st 2 pins on the left were 3.5k ohms when they should be 1.5. So he believes it is letting too much gas pass. Need a new valve apparently.
Jusy bought myself a gas valve and now I csnnot get to the nuts to take it out. It says in the book the valve comes with a service spanner but it don't. What do you guys use?
I tried with grips and all kinds of spanners but no joy. I cannot believe in 2 weeks I have bought parts with the sockets that they're supposed to come with missing:-(
I tried my mini socket set but couldn't get it between casing above and nut. I can get the one at the front, but the 2 at the back are being troublesome
Reply to the thread, titled "Explosive ignition problem" which is posted in Central Heating Forum on Plumbers Forums.
Bhoydavid,
Killy Bing,
