Finding a blockage in heating pipework
View the thread, titled "Finding a blockage in heating pipework" which is posted in Gaining Plumbing Experience on UK Plumbers Forums.
If it looks grey but is fairly soft and silver if you scratch it it's likely to be lead. Lead was still used up until about, say, 1970.
Anyway, the techniques used for jointing lead are not quite the same as for copper tubing and I would recommend you don't make the first time you try it on a customer's system.
There are a couple of people who are active posters (Last Plumber and JustinLead1 come to mind) who have mentioned they have leadwork skills. Probably best to upload a couple of photos and hope they drop in.
Def not lead. Exactly like copper but silver. Cheers chuck
Standard compressions will be ok?
Not if it's what I think it is (galvanised steel). You'll need to use a 'dielectric' coupling and put a thread on the end of the steel pipe. There may be other methods, my only real experience of steel pipe is seeing it in a skip after someone else has ripped it out. But... I'd describe it as looking more 'grey' than 'silver' (think electrical conduit). 'Silver' could describe stainless-steel, but I've never seen that in domestic premises.
Sorry, I think you'll need to post a picture for a postive id.
So the branch left (to rad) was hot up to the tee, the branch top (to boiler) wasn't as hot but was still quite warm, the oth 2 branches were cold.
Logic told me the blockage was in the tee. My logic was mistaken!
Any help would be grand!
UPDATE: the branch bottom I believe is the old cold feed as it appears to be capped (not entirely sure but the pipe is loose so I can only presume and it goes in same direction as the flow to old cylinder.
any chance this could been an air lock? Doubt it as flush woulda cleared it but just putting it out there lol
That pipe looks from the photo like Truweld, (brand name ), it was used during the copper shortage in the 60's and most of the stuff I've seen is steel pipe, thin walled which had been tinned so it could be soldered like copper.
My advice to you, if the customer is willing is to get shut.
You have two options
1 you know the blockage is on the main run, so start one end and cut and splice until you find it
2 re pipe
It's def not that tee. but still not getting any return flow past first two rads
If I were you I'd just talk to the customer regarding replacing heating pipes. You spent so much time and work on trying to solve it. Now, it's time to make him realise you will need to replace big sections of pipework to make things working. The best way would be replacing the heating system completely. But that's just my opinion
Reply to the thread, titled "Finding a blockage in heating pipework" which is posted in Gaining Plumbing Experience on Plumbers Forums.
jaydebruyne,
Old Account,
