starshine
Ive got a coal effect gass fire, the flames come up through
the coals.
It has a brass surround and a slider at the side turns it on.
The ignition is nt working and when manually lit the flames
are not there, the control seems to be gone.
Speaking to a plumber he said, well the fire is 14 years old,
its come to the end of its life, it needs taking out and a new fire
putting in.
Thinking about it , the fire was put in with a lot of expense,
it does look very good but really, a fire like this , once fitted
should last a long, long time.
In the end it is the gas going to a metal plate with holes, the gas going through the holes ... just like your gas cooker...
then flames as it goes through the charcoal like coals.
Its basically simple
I just don't see why the whole thing should be ripped out and replaced when basically it is the switch and ignition that has worn out.
Surely a bit of plumbing could bypass all the fancy ignition.. the pipe perhaps come onto the hearth... a simple valve switch to turn on the gas, a gas lighter to ignite the gas fire..... am I wrong ?
Yes. You can't modify a gas appliance for a number if reasons.
Get a second opinion, it may be repairable if the parts are still available.
Try posting in the 'I'm looking for' section
Two other simple and not complicated issues
1. Carbon monoxide kills
2. Gas and air mixed with ignition can be explosive
Nothing lasts for ever. When was it serviced last? I mean if I fitted an expensive bit of kit in my house I would maintain it to prolong its life due to the considerable expense I had gone to to install it?
That fancy ignition, just happens to be the fires main safety device. Do not use it unless it can be properly fixed by a GSR with approved manufacturers parts.
We cannot and will not give advice on the installation or repair of boilers, cookers or ANY gas appliances for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - View Profile: gas man - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK or Redsaw - View Profile: REDSAW - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competence is unacceptable. We will take whatever action we deem appropriate to prevent such advice being given
Thank you.
UKPF TA's, Mods and Admin teams.
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
