Fitting old pipe to new
View the thread, titled "Fitting old pipe to new" which is posted in UK Plumbers Forums on UK Plumbers Forums.
starbs
Evening I've got a job on at the moment and I'm not sure what they used to plumb with years ago but the size of the pipe is all to pop. I've gotta join into some old pipe and well the hot supply pipe is measuring 21mm externally what fitting can I use? I've tried soldering a 22mm fitting and well the solder just won't bridge the gap any ideas how I can get a fitting to connect that upto some proper 22mm copper
Cheers
Haha how new to the industry are ya
imperial pipe sir
you want to stock up on 3/4 to 22mm couplers.
1/2 to 15mm isnt too bad as you can solder onto it usually
End feeds should cost no more than 40p. (a green ring less)
Where are these "plumbers" coming from these days...........wait, i know............the 5k skool of plumbing where you do your real learning at the customers expense!
It was a yorkshie imperial fitting for a gas line under a floor that had compression fittings on it. Not only that I was out of my area and it was half 4. I had no option, no other merchant for miles.
imperial pipe sir
yeah I am new to the trade but this mixing of inches and millimetres is just wrong !
3/4" is still used in Ireland. This is your job so learn it. Grab one of those mags from the merchants next time you are in and circle all the things that interest you on the card at the back and send it away.
You'll get a pile of stuff in from manu's. Read it then send for more.
Half this job is knowing what you can use where.
I cant remember ever finding 3/4 copper used for gas pipes, always barrel or metric.
Gas engineers down Sarf must have either being really strong or tight in the old days
Still loads of old size 3/4" gas pipe (Copper) & water supplies, you lot who are not coming across is must just be working on new build
hi guys its hurdy:17: well,have you not heard of metric to imperal fittings will get you out of a scrape i dont see a problem,:waving:
Reply to the thread, titled "Fitting old pipe to new" which is posted in UK Plumbers Forums on Plumbers Forums.
starbs,
hurdy,
