May 5, 2020
86
DIY or Homeowner
I seem to find a lot of different opinions on fixing walk-in shower trays to floors. I will be fixing to a marine ply base screwed into joists with noggins. The manufacturer says bed into a weak mortar mix, but I read that this can lead to problems when the mortar dries out. Some say silicon, some say low expansion foam, some say tile adhesive, some say mortar.
What is the definitive way to fix a shower tray?
200kg is a bit excessive, good chance that the weight actually bowed the tray as it set unfortunately and once removed it is just will just spring back.
Never seen people weigh trays down as they are normally heavy enough to start with.
As said above if there is any movement on the tray it is likely to crack or break the seal with the tiles/wall etc.
Are you able to wedge the edges down in the wall to stop the movement. Unless it is completely solid I wouldn't continue with the installation unfortunately.
I think for sure what's happened is, by putting the weight around the edges, I've bowed the tray a tiny bit while the mortar set. Once I took the weight off, it left a bit of spring at the edges.
All stripped now and ready to try again. I contacted the tray manufacturer and they say I can use tile adhesive as long as it contains portland cement. I assume Mapei flexible adhesive does, that's what I'm about to use.
They also say don't weight the tray, just settle it in.
Fingers crossed I get it right this time!
  • Winner
Reactions: king of pipes
So I have now bedded the tray using flexible tile adhesive. Probably used way too much on the advice of another plumber and the tray is now sitting on a good 10mm of adhesive above the plywood base. It's level though and I can use a bit of quadrant to hide the gap once the flooring is in.
Had a tray once that I set twice with a 10mm and there was movement both times. Set it on 18mm shrank down to about 10mm once level (sorted) but looked a little odd. Couldn’t notice once siliconed the edge though.
