Nas
133
Hi does anyone have the manual for this gas fire or know where the spilage test point is. I tested it on the RH side but it was spilling loads do I've capped it off. Just wanted to make sure I tested it at the correct point.
Thanks in advance
Them are the ones I've got as well the emberglow II is slghtly different.
Its at the back, 25mm beneath the draught diverter at a 45 degree angle. You'll need a bit of 10mm to pop the match in to reach it.
Just found a copy, not explicitly for the emberglow 2 but it's the same. Tried attaching it but at 1.4mb it's too large. Pm me and i'll email it.
This is how it looks from the back. Its not Like the emberglow classic there's no space to get the smoke match from the bottom.
that looks like test point on left of picture ?
Thats what I thought, But the amount it was spilling was unbelievable (pretty much 90%). Made me think It wasnt the correct test point. Not come across this model before so I just wanted to confirm with someone else.
probs a flue problem ?
No the flue was fine It had a good pull. The gas fire needed a service as Burner pressure was high, indicating blocked injectors. I tried to clear the injectors and failed. It wasn't giving out enough heat by my reckoning before and after the service.
Here you are. For G.C number 32-274-52. The instructions show two ways of testing; it appears testing from the rear is the preferred method but if furniture obstructs this the 2nd picture is acceptable.Emberglow II 1st.jpgEmberglow II 2nd.jpg
