I aimed to put the jointing compound on the end of the pipe but I often put too much on which squeezed it into the thread.
Does it go hard or does it stay soft?
On the bit where I have lots of compression joints, I have about an inch of original 15mm pipe to work with as it goes off behind some boxing.
I've seen compound that's set solid before now, no idea what kind as I was the one trying to clean it off, not put it on.
As I said, just a smear on the olive will be plenty 😉
Depends on what paste you used. I use Jet Lube V2, which will never harden and is for potable water. If you used Boss White or similar, you shouldn't really have as they will harden with heat and really only for heating pipes.
Boss White is one of them. It oozes into threads of nuts and sets hard. It has a linseed oil base.
I used Fernox Water Hawk or something - from Screwfix.
Its like chewing gum.
I am not sure about that. Some of the Fernox paste is near identical to Boss White.
It is supposed to be potable on all cold and hot supplies.
Boss White has been used for years - now it is wrong to do so, but whether it actually does any harm or not is hard to know.
Edit, - just looked it up and I see it is, as its name suggests, Fernox Water Hawk is for potable water, so nothing wrong with it.
ok well i will see if i can get a pipe bender off someone i know at work tomorrow, if not i can hire one for a tenner or buy a cheapo from wickes for £25.
I could do the rigid pipe with a few comrpession joints i spose but i fancy a go on the pipe bender.
if i buy the oen from wickes is there any way i can try and forsee if it wil lcrease pipes before I buy?
The usual cause of copper pipe creasing in a bender is cheap copper.
Buy quality British copper pipe from your local independant merchant, don't get it from one of the big sheds.
Had my first pipe bender about 10 years and it only used to cause creases with cheap copper, it wasn't an age thing, or temperature thing and I used the same guides etc. on every piece of pipe I bent.
Although I might add that 22mm was partial to the occasional ripple, even with quality copper.
Nahh cheap, dimensionally incorrect guides everytime.
I buy the cheapest copper i can get my mits on.
It has the same BS as the expensive stuff.
I never have a problem with it throating. Only ever with nasty cheap benders.
Maybe im just lucky !
Usually the isolating valves are never needed and can seize up or leak if not decent quality IMO.
Not needed I believe.
As per the water regs each appliances/outlet should have the ability to be independently isolated
All though I agree there usually useless I still fit them to everything where practical, but usually just put to good quality full bores on the hot and cold incoming into the bathroom
I don't like flexi's personally but have used them in difficult tight spaces, the key is to buy wras ones and not kink or twist them up and really you only need to have isolation valves on float operated valves for maintenance.
The regs state that float operated valves need to be isolated. Doesn't actually mention about any other appliance
Like this?
This is like top-trumps.
(BS6700)
[emoji12]
I never use isolating valves on baths. If I had to use them, I would use full flow best quality valves. Those ordinary cheap isolating valves, as we know, are trouble.
I don't see the point in valves on bath supplies, as on the very rare occasion you need to do a simple repair to the bath taps, it just needs the water turned off briefly. Don't want to remove a bath panel just to turn valves off. And when a bath tap needs totally replaced, or when a bath has to be removed, it's easy just to plug the pipes temporary.
Truth is none of us know what the risks of fleximagigs really are.
We go on personal experience and hearsay. The plural of anecdote is not data.
If we had access to total estimated flexible hoses installed over a ten year period - biggest sample size possible plus total estimated bursts, referenced against instances of poor installation, it'd make for some interesting reading but I bet we'd all be suprised at the figures one way or another just because we don't know.
What percentage of 100,000 moderately improperly installed flexi's (not massively snaking or twisted) will burst within ten years? Guesses on a postcard.
