Got called out to a job today from a confused customer who just had her boiler serviced by home serve , her boiler was previously covered by BG. The previous engineer who left about 90 mins before i got there had supposed serviced her boiler under the cover she pays for.He informed her that her gas system had 3 mbar drop over test limit no smell gas and everything was fine then left .
Confused she called me i arrive confirm pressure drop on her boiler ( 1st engineer told her gas fire).I then suspect that no real service had occurred as notice pressure was low.Boiler was also full of air as air separator was closed then i asked how he checked flue? Cust says he said he couldn't inspect it as he never knew where it went . I found out flue has been boxed in a void since house was built ten year ago no hatches , so i end up removing a panel to nose at flue and see what i think is incorrect terminal on a condensing boiler .
However i can't get in far enough to fully inspect flue so have attached piccie , are my suspicions correct?
BTW previous engineer never even noted about a flue in void on paperwork either !!!!
Current situation boiler is capped .
