R
Ray Stafford
Please see this youtube video for a demonstration of the Aladdin Easifit isolator, or visit their website here.
Its a 15mm lever valve that you can fit to a live pipe, without draining, freezing, bunging or soaking yourself in water. Ideal for namby-pamby plumbers who don't fancy doing a cold mains live, or cutting into a murky heating pipe over a white carpet. 🙂
It fits 15mm copper, Hep, Polyplumb, speedfit etc, and leaves you with a permanent full-bore lever valve in place.
At just under £30 + vat they aren't cheap - but on the other hand, neither is hours of labour draining and refilling, and freezing isn't always feasible particularly if there is any flow. We are including the toolkit in the freebie.
I have 5 to give away for review. The first 1 goes to Rodolphe for drawing my attention to it at Phex, and the 2nd goes to Bod - I can't remember why, but I have a note that Bod deserves one for some reason. The other three will go to the first three plumbers arms members who PM me their postal address.* Other members - sorry, but if you are a professional plumber, build a good post-count, and apply to get into the arms!
A big thanks to John at NLB Engineering for providing the freebies.
As always, its a condition of the freebie that you promise to come back on the site and post a review. There is a sticky thread for the purpose. The review does not have to be positive, but if you have criticisms please keep them polite and constructive! Sensible feedback (even if its negative) encourages manufacturers to provide the freebies to keep these giveaways going.
Cheers
Ray
*Members ineligible for freebies until they review the Calshot or IntaKlean freebies are: APPlumbing, Croppie, kay-jay, Mike Jackson, JCPLumb, Anz, Stani, Redsaw, Orry Clayton, Destroyer2813, Stevetheplumber.
why cant it be frozen dannypipe, let us no how you get on i was thinking if you had a burst pipe and the mains running full boar could this be fitted if toby cant be found
If there was an option to have it cheaper without the fitting kit, I probably would have gone for it, as I have all the components on board anyway. Only thing is there is a red alignment line on the socket they give you in the kit so that you know you've gone to the right depth.
It can't be frozen because the stopcock is broken, and the problem outlet is leaking (a fast drip). So even with my powerful freezing machine, I wouldn't like to bank on it freezing a solid slug in the pipe work. As we all know, running water doesn't freeze well!
I started talking about trying to tape up the outlet with almagamating tape, and freezing it, when I remembered the valve, and the customer said, just do that. It's take 15 mins for the machine to freeze a 15mm pipe even if it isn't leaking. So time against costs. This works out much the muchness!
Looking at the video, I reckon I could fit one of these in about 2 mins or less...but I may eat my words.
I think so. half inch is so close a match to 15mm I think it must. I would imagine the 22mm one (when it comes out) will have a big notice saying it doesn't work for imperial pipe work. (Just like a pushfit doesn't).
It crushes it, and pushes it to the back of the valve. (That's the clever bit in my opinion).
Weird blade on the cutter. Not toothed as they don't want it to produce any swarf. Must say I'm impressed.
