View the thread, titled "Full bore or Lever valve?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
I am thinking of making some improvements. I want to replace the existing isolating / stop valves which I think are just standard ones to full bore valves. However for ease of use I would like to have valves with a lever but I can't seem to find a full bore lever valve.
On screwfix I see the following.
https://www.NoLinkingToThis/p/full-bore-isolating-valve-15mm/46860
But the following it says its a ball valve.
https://www.NoLinkingToThis/p/lever-ball-valve-red-15mm/67744
Which is better for isolating the supply - will be in bathroom.
Did you read it properly/fully?
Sorry but my explanation was a bit poor. The existing stop valves I want to replace are the ones connected to the sink and bath.
So copper pipes currently terminates in a isolating valve that requires a screw to operate. So an isolating valve that is full bore, has a lever and can connect to the sink and bath flexible tails.
Butterfly handle iso ball valves will do if you want easier use and you can't use a slotted iso ball valve as you listed.
That looks perfect. Can a sink / bath tail be connected to that?
The reason I am looking for a flat face isolating connector is from this video. 1m 10s in but then he says not that he has had leaks from a standard fitting - so not sure.
Do these come with a compression fitting on one end and a flat connector on the other end to attach basin taps, toilet inlet valves.
I thought I could connect these to flexi tails.
Or do I need another connector?
You can stick a flexi straight on. Just slightly more than hand tight. You can get "flat faced" specially for flexi but not sure they come as a butterfly.
I have a 22mm bath filler tap and 15mm pipes. So I need a flexi that will connect from the bath tap to an isolation valve that is full bore and if possivle lever - but screw operation is acceptable.
Any valve is in essence a service valve.
I always use full bore lever valves, there is rarely a situation where it can’t fit. If needed, cut down the handle or put it in the vise and bend it.
If you’re gonna attach a rubber flexi to it, I always give the compression end a slight file to flatten it.
Reply to the thread, titled "Full bore or Lever valve?" which is posted in UK Plumbers Forums on Plumbers Forums.
Thread starter
Joined
DIY or Homeowner
Thread Information
Title
Prefix
N/A
Forum
UK Plumbers Forums
Start date
Last reply date
Unsolved
Thread Tags
Tags Tags
valve
Justice League,
Timmy D,
