gas cooker
View the thread, titled "gas cooker" which is posted in Gas Engineers Forum on UK Plumbers Forums.
£100 a pop aint bad by any shout , you sure they dont ask for ckr1 as its contract work??
As for gas safe nothing suprises me with them as last time i rang tech help i got told off for not having my viper book with me which i left at home and ended with no answer for my query.
I'm sure i questioned the hob scenario with gas safe due to a floating kitchen worktop if memory serves correct gave him my reg i.d and said hob has to be rigid not on flex (which i altready knew) but wanted confirmation.Asked if i could fit it and was told yes due to pipework.
Id be careful mate, if anything were to happen they would probably deny ever telling you anything.
Nah I was asked what Id be working on and just sat the relevant tickets, never even questioned it, especially as it covers hobs in the assessment.
Heoliotrope is correct. There is no requirement to cap off an unused bayonet connection. It may be considered good practice but there is nothing anywhere saying it has to be.
And regardless of what someone at gas safe said, you need a ticket to fit hobs. Not because it is hard to do but you need to be aware of the clearances and ventilation.
o.k so on re-connection your surely breaking into the gas supply which is deemed as gas work??
How does that equate ?
Cust cant take boiler cover off for e.g as its classified as gas work by gsr but has not broke into a gas supply yet can push a fitting into a live gas supply ,,,,,,,one word 'joke'
A gas poker may be a better example of something that is plugged in and out of a bayonet fitting a lot more regularly than a cooker hose.
Imagine having to phone a gas guy every time you lit the fire.
What am getting at is hypocracy of it all , your basically being told you can plug into bayonette yet cant be trusted to ptfe cooker hose , test,gas,rate etc etc etc ,yet can put all pipe work in , do boilers , do service on fire , open flued appliances ,ventilation blah blah blah but incompetent to ptfe a cooker hose because dont have a licence !!
i suggest this conversation taken over to the gas safe forum where all are invited, providing you are registered?.
you sure redsaw? we are debating who can do it, if anyone can disconnect a cooker why should it be offered only to gsr?
I do think its ridiculous that they are basically saying that your capable at everything else for e.g but you dont have a cooker cert they are saying your not capable of ptfe'ing a hose !!
Mi's will tell you about ventilation /clearances plus you do ventilation on your ccn1 , failing that just blast a 4 inch core througf the wall .
many things have these type connectors, consider lpg heaters, cookers etc, no gsr required, we would ruin many camping expeditions if it were
well thats what i am saying is the hypocracy of it all , they can disconnect a cooker yet not allowed to take a boiler casing off as removing a boiler cover is classed as gas work and you need to be gsr registered .
As for ptfe the hose to cooker thats a joke in its own right !1
of course it is. who says if its a positive pressure boiler or not, and ptfe is ptfe, just slap it on?.
if the current system isnt correct or is hypocritical, what isnt? where do you suggest the line is drawn then?
Well a line is never going to be drawn as its all about money as per usual bpec gas safe etc .
i think you will find mate that wats been said earlier is correct and is only temporary, sure when i done my gas it said if it was being left for any length of time after 24 hours it has to be permenently capped
a properly fitted and not leaking bayonet can be left as a permanent point of disconnection, there is NO timescale for a disconnection, as there is no temporary gas work, it is either acceptable to disconnect it or it isnt acceptable, having a timescale on it doent make sense
No need to look into it had it straight from gas safe as already asked in the past , hob on rigid pipework .
sorry but that is not the case and i would suggest a wee phone call to GSR tomorrow to confirm the confusion of your last conversation, as i can state 100% you MUST have CKR1 to fit a hob
part of the conversations might be about who can and cannot disconnect a hose and bayonet, but we also have comments about people fitting hobs with only CCN1 which is wrong and will only create havoc for those reading it and should be taken to the gas only section, as it isnt very professional to have GSR's debating what quals you need to fit a hob
All this confusion just shows how bureaucratic we've become in this country.
Seems to me that good old fashioned common sense has been left far behind.
i dont follow your logic saying you dont need CKR1 to fit hobs to solid pipe (and i bet you dont have an email confirming this, and i bet you even more you cant get one tomorrow) as you can read about clearances and ventilation in the MI, do you have HTR1 or do you connect fires to rigid pipe and read about ventilation in the MI's
It was a conversation over an issue with a hob to gsr tech helpline about two years ago.
apologies for banging on about it, but i can categorically state you cannot fit a hob with CCN1 ticket, so the conversation you had with GSR must have got confused and i can also tell you categorically that IF you fit a hob without CKR1 and something goes wrong and you quote a phone call from 2yrs ago as your defence in court you will get slaughtered, i appreciate you have taken this advice from GSR in good faith (as you should) but it is wrong, i spoke to CORGI inspectors yrs ago about technical advice issues and they said one of the biggest problems was making sure they understood what the caller meant, and to be sure that they got the right info across, but were very wary of emailing advice in case it was taken out of context
i am not fitting hobs nor cookers as dont have ticket and reason never done the ticket is because doesnt seem to be much money it where i live. As for tech advice or with gsr lack of tech advice then if they arnt capable of giving clear cut answers then they are only confusing the issue thenmselves and should only email clear cut answers.
L:ike i said earlier if a home owner can connect/disconnect a cooker then why should they have to be gsr to take boiler cover off?? Different story if its invasive gas work yes but to take a cover off ??
have on site yes , my own works no as cant be bothered .hence why never bothered with cooker ticket .
correct me if i miss read this but if you aint got the ticket and you have fitted cookers on site then its a bit of a no no?. no.
Depends how you read it,
Have worked all over the country and there are guys on most sites i have worked on installing boilers,hobs,cookers,gas pipe work and dont have a gas ticket to their name. However thier is a commissioning guy who will come oout and commission all appliances installed ,it also works same way with unvented cylinders.
Normally on site there will be a gas certified op but doesnt mean those works stop if theyu go sick or on holiday.Correct me if i am wrong but if their is a gas op on site then the theory goes he is over seeing the work (even tho it is a technacality) of the installs. Besides i have also seen gas safe ops who iwouldn't trust to fix a stand off clip never mind install commission any form of appliance.
find it hard to understand that. your saying that the regs are being broke on a large scale then?.
i mean, the work can only be supervised if monitored from start to finish and the relevant ticket holder has not left the side of the installer?.
Saying exactly that !!!
I have worked on many new builds where guys dont have any gas experience what so ever and yet are installing boilers and hobs .
i worked with a guy that never had any gas experience at all yet had a u gauge and would test to what he thought was the method of a tt.
I worked for a large company ( no names) a few years ago that had a guy on site installing boilkers and hobs and was only third year apprentice . Like i said have worked all over and yes this goes on at a rather large scale.
It is done big time Red. All within the rules. Some of the bigger outfits may only have one or 2 registered guys.
Reply to the thread, titled "gas cooker" which is posted in Gas Engineers Forum on Plumbers Forums.
Thread Information
Title
gas cooker
Prefix
N/A
Forum
Gas Engineers Forum
Start date
Last reply date
franz,
gaspastemania,
