Feb 6, 2019
Heating Engineer (Has GSR)
Gas fitter here needing some experienced plumbers advice.
A family member has had a new kitchen + bathroom fitted. The hot water coming from her gravity tank has a very poor flow rate now at all her taps, as does the cold mains, strangely. After checking the usual suspects - stopcock, water in tank etc I then attached a water pressure gauge to the cold mains pipe going to the kitchen sink and was getting 1.5 bar. Hot water was around 0.1 bar which is pretty normal I believe for each. Yet very poor flow rate coming thru the actual taps. I done the same checks in the bathroom sink + bath and same outcome. Toilet is filling fine and electric shower pressure is fine.
Is this due to the “wrong” kind of taps fitted? The old taps were all individual full turn types. Now theyre all mixer tap 1/4 turns. The ones in the bathroom are the waterfall type. Could these new tap choices be designed for a different pressure or could the 1-4 turn type be wrong in some way?
Any advice appreciated cheers.
are they fitted on flex connections some of these are quite flow restrictiong also are there isolations valves if these are not full bore they also restrict flow
You are correct you can get low pressure taps. But as above check for kinks in flexi pipes
Yes onto flexi’s mate and have isolation valves, however the pressure after the isolation valve on the mains side is 1.5 bar, so I don’t think the iso valves are the issue, the pressure after each iso valve is fine as id disconnected and checked, so the only possible things are the flexi hoses and the taps themselves, the water is dramatically reduced coming out each tap for hot and cold, could it be a mixture of flexis and incorrect taps?
I think its more likely that the taps are the main issue although flexis & iso are probably contributing. Could you try scrapping the flexi and iso valve (or swap it for full bore) on one of the taps? Also have they still got the original taps to hand? If so you could swap one of the new taps for an original one, connecting it to the flexi. This would be a fairly cheap and quick way to rule things out.
Can’t see what brand the taps are unfortunately, and I don’t have the old taps
So when you say full bore taps, do you mean taps with 15mm straight into them?
Ask them where they bought them they could be off eBay. They could be some tat from vp
No ptfe or anything else present, 90% sure now it’s flexis and incorrect taps... for future reference do you guys match certain taps to specific water pressures? As in gravity water = low pressure compatible taps?
Reactions: Riley
The waterfall tap I have on my bath has pre-fitted flow restrictors, I didn't take them out before fitting and I now regret it as the flow is awful.
One day I'll get the time to take the panel off and remove the buggers.
Maybe your waterfall tap has these too?
I think you are spot on mate I will check for these too!
Have you checked the filters on the outlet? Kitchen mixer will probably have a high pressure filter on its outlet which clogs up easy and some of the waterfall taps I've came across have a mesh filter in the outlet too.
Could also be the tap isn't designed for low pressure systems, if you know the tap make and model, check the min specs online
Full bore was in reference to the isolation valves, the standard ball-o-fix isolation valves are only about 8mm inside.
Reactions: ShaunM81
There is much nonsense talked about tap flow rates. There is no formal definition of low or high pressure so one manus hi is another's lo. It's literally a lottery. From what you say in your original post, NO 1/4 turn tap or single lever tap will give you even reasonable flow rates. You are better off converting 1/4 turn to traditional multiturn. Yes, it can be done.
What you are trying to achieve is flow rate i.e. how much water flows into the bowl in a set period. While pressure has an impact on that, its the dynamic pressure (i.e. when open) that is counts not the static pressure (when closed). The static will always be higher.
Flow rate, just like through a combi, is deeply affected by ANY and EVERY restriction. For a low pressure HW system like this one then you MUST use hard tap tails (can be bought seperately) and full bore iso valves. Check EVERY valve on the supply pipework cos ANY valve that is not full bore will utterly compromise flow. If you had 35mm pipework from the cylinder to the tap and a cheap iso with its 8mm hole then your pipework is effectively 8mm in dia. It's NOT the same as gas.
HTH 😉
