Gas hob connection
View the thread, titled "Gas hob connection" which is posted in Gas Engineers Forum on UK Plumbers Forums.
Chalked
Just came across these on Williams site.
are these ok for a job, as it's not a solid piped connection?
It's new, and will at some time make a job so easy, just not sure when you have the smallest space behind a built under cooker that this will fit. Recently the BU cookers we have been fitting have only just enough room for a 15mm tube never mind a covered pipe.
The spec does say for static appliances it's not to be used on moveable appliances.
Am I missing something here. Some manus say it's ok to use a cooker hose with the installation of a hob, now this product. Surely the MIs outweigh any other decisions to make?? I agree we'll definitely find these installed wrongly but we'll always find other people thinking they know best or not adhering to mis
There was a tb on these a while back can't remember what no but it was in there
but guess it's the same as some mi say it's ok to use a cooker flex
But this is my point yes there is a part for it but unless the manufacturer says it's okay to use it on their product then the point is moot???
Still trying to work out what the point is or why you would want to use one
Have to say I agree mate, I've never come across a hob that I can't hard pipe. It's obviously fine that Ray is selling it as he doesn't sell to Joe public but to me this is yet another example encouraging people to DIY gas work
think it said it could be used on any weather mis say yes or not
This is my point mate I had one of these little while ago in a landlord property whenever I find one on a cooker hose I always ring the manufacturers or try and find the installation manual. The last one I looked at specifically said not to be piped on a flexible hose. Now surely this is in line with the manufacturers guidelines and as such should supersede anything else?
the problem is would you class trac pipe as flexible i wouldnt, but then thats my opinion
think the term flexible is meant for cooker hoses
At end of day MI's rule.
Some of the hob MI's actually state flexible steel pipe may be used and the TB a while back confirms this new option on the market.
Unless MI's specifically state otherwise then rigid pipe supply to hob it is!
Reply to the thread, titled "Gas hob connection" which is posted in Gas Engineers Forum on Plumbers Forums.
Chalked,
GrahamM,
