R
Beat me to it!!!
could be across the meter?
Apologies 0808 how do you mean so I can go back to him with some alternative testingEasy check, cap the meter
LDF is leak detection fluid!! By across the meter it means either a leak from the inlet or outlet or the meter itself, from the ECV or anaconda... Capping the meter would check all of this!!!
i take its 22mm throughout?. i bet its a leak in the wall where its plastered over near the meter
Any doubts about running the pipe up the front of the house from the meter into the eaves through into my loft space and then down into my boiler. Also as another point have any of you come across any good external trunking to cover the pipe that can be painted etc... Also i have read that the pipe if painted needs to be yellow?That's up to you. He can test along every inch of the pipe by taking your house half to bits, or he can suggest an alternative route to replace it.
