I can see the figures in your last post. But I thought .5 for each elbow and tee .3 for formed bend?
I didn't know there is pin point figures from the bs6891 2015
On the gastite website there is detailed pipe pressure losses for even couplings. Is this what you do for precise measurements?
The book we have been given from college said this is all we need to know to pass. When did it come out?
Maximum allowance from meter to appliance 1mbar. From the meter work out the consumption rate of a a meter of pipe up to the maximum of 35mm diameter. The larger pipe bore the more retained.
Then reduce the sizing slightly further down the run. And not forgetting to + 0.5 of resistance for each and every fitting then adding in to actual length.
