Atanas Peev
16
London
Heating Engineer (Has GSR)
Hello any with experienced with gas valve low voltage The boiler is Vaillant eco tec pro 24 I’ve got a code F61 and voltage to gas valve solenoid is 4.51v dc
Regards Atanas
Unfortunately. You will need a registered gas safe engineer to fix your issue as to inspect the gas valve the case has to be removed from the boiler .
Reactions: Lou
A gas safe engineer will be able to diagnose and repair your boiler we cannot give you any advice regarding gas repairs in the public domain on this forum . Apologies kop
Reactions: Lou
He is gas safe lads and tbh don’t know what happened but it appears he’s lost the gsr badge as I’m sure I’m the one who processed it 😀
[automerge]1571524819[/automerge]
Check the voltage at the board if the voltage is good there then loom is probably bad if not
Then I would suspect the pcb
