SimR
Hi all, I've looked at the other threads on Geberit flushes but am still not sure if this problem - well it's actually 2 problems - was/were covered. So here goes -
I have a Geberit concealed flush system and sometimes when I use the full flush it stick and water keeps running in the bowl after the flush. I have replaced the whole valve system (everything that connects to the water pipe but the problem persists. Any ideas?
In another bathroom - the same system - you have to hold the flush down for a total flush - if you push and release - the flush stops. Again I replaced the entire valve system but no dice. Any help - much appreciated.
Thanks in advance.
Thanks in advance.
