when to see this boiler today as it wasn't working, its an old balanced flue conventional boiler, pilot wouldn't ignite, i eventually managed to get it to work but when i did it wasn't really in good condition, with the casing off when I fired up the burner the flames would burst out from below the burner and come up the sides of the combustion chamber, also the flames were really orange and yellow, signs of scorching on the outer casing, I ID'd the boiler because the casing was leaking POC's as it needs new seals.
my question is why are the flames bursting out ? it also stinks of gas when in operation, with the casing on you can't tell if it still does this but without the casing on it does not look safe, I didnt have my ladders with me today so couldnt inspect the flue.
also there was no ECV in the flat, gas meter was outside and not easily accessible unless you jumped a fence for quickness, I AR'd this but was wondering if I was right ?
