J
jfb
Hello everyone, I have been asked to repair a Glowworm micron 50ff boiler. The boilers reset light is illuminated and the burner indicator light is flashing on the fault finding chart this indcates softwaree problem. The boiler is othwise not working. I suspect the PCB is us. This happened after the customer had her gas meter changed. Has anyone any experience of these boilers that could give an opinion on this
Someone else will appear and point you to the correct admin for you to prove your gsr to and be able to ask this in the private gas safe forum.
this cant be answered on the public version.
you are gas safe registered correct?
give me your gsr details via pm,answer a few questions once i am satisfied you are gas safe reg,an competent around a gas appliance you can ask this in the private gas safe section,if however you are a john wayne you can rotate sunshine
