Raxi Solo !!
Ah the old he plus !
Yes to my own question it only needs 50 mm clearance at the bottom, fun emptying the condense drain then !
Next question What news paper was it ???
I have had 2 x local plumbers send me the same pic.
One of them initially put my name forward to price the job, an old floor standing Rs boiler on gravity with a split coil in the cylinder.
Rather than do a full convert to fully pumped the chosen installer has just put a pump on the returns and told the old girl to turn off the rads when she does'nt want them on :smug2:.
He did raise the expansion tank tho, which he thought might help the split coil in the cylinder !!!!!
Sorry cant make out the model of the new boiler but can it be fitted under a work top ??
is the bit of aluminium a heat shield for when the paper gets going.?
IMO total over reaction. That flue never gets hot.
Never will get hot
There's worse things out there. And if there was a bit if plaster board over the front of that nobody would know
I know it will never light, inner flue only 55 degrees.
..... Was meant to be humour! Oh well.
Reminds me of the flue I came across when replacing an expansion vessel had to break the plaster around the flue only to find the huge void and cavity stuffed with T shirts.
What?
Lagging was acoustic , to stop the heavily clipped pipes resonating when in shower. Lady of the house couldn't wash her junk in peace !
Found this pic from a few years back. Warmfront job, boiler had been turned off due to low inlet working gas pressure. Warmsure had said that pipework was undersized as it was mainly 15mm to a 24Kw isar. I turned up to repipe and found the meter less than 6 foot from the boiler with about 4 ft of 15mm. I could see why the original installer hadn't upgraded it as it disappeared behind the unit and re appeared through the worktop. A repipe would have entailed destroying the unit. I turned back on and tested, pipework was gas tight, 21 working at meter, 8 at boiler (which was surprisingly working). Obviously some sort of blockage and my eye was drawn to a new compression fitting where the new pipework from the meter was connected to the old pipework running through the cupboard.
I took the fitting apart and found
bhw2646 by Mike Jackson1, on Flickr
A good illustration of why, if pasting joints, you should take the nut and olive off and paste it on the pipe rather than wiping paste in the joint.
Funny how the original installer had signed the boiler off with an inlet working pressure of 20 mbar. The paste must have got into the joint on it's own. I was also ticked off that the old lady had been left with no heating or hot water when it took me 5 minutes to rectify. It wouldn't have hurt the warmsure engineer to spend 5 minutes looking for a blockage rather than doing the usual TOFO.
Keefy - lol ur dead right! Polyester wrappings. Used long time ago to hold in heat. It did aswell, was like a sauna when i took the cupboard apart. Just rub salt in wounds, they have JUST had new bathroom fitted inc new tiles. All the cupboard was tiled to, extremely tight! Was so suprised i didnt smash either basin, toilet or any of the tiles!! Lol
