HALL of SHAME PHOTo`s
See anything wrong?
Agree service valve on vent side lol love to see it implode lol
And that lazy couldn't solder a bend on
Just read this from start to finish, unbelievable the same poor lads seem to keep finding these installs I see hardly anything like these, nothing dangerous just poor workmanship normally.
Ill post a few pics....
^^ you joke Bod but i went to a job where some numpty had fitted a surry flange and replaced the vent pipe with a auto air vent and a 2 bar pump which must of pumped back and belled out the bottom of the cylinder. When i took it out a 48x18 cylinder was 6 inch"s out of level the only thing that saved it was it went backwards against a wall and not out of the door
Finished Fitting a new combi to a property on Monday and no matter what I tried I couldn't get any heat to the drops. With all the rads bar the drops turned off the return to the boiler was red hot but none of the rads were getting hot. This led me to believe that there must be some sort of bypass on the system. I Lifted a few boards and checked the return and it was stone cold as far as the bathroom. The only place there could be a problem was under the tiled bathroom floor.
I returned today with a borescope and struck lucky on the third hole I drilled in the ceiling. I found this.
Bypass by Mike Jackson1, on Flickr
No wonder the drops wouldn't heat up.
That's some drill bit to drill big oblong holes 😀
Yeah, looks good. Where can I get one of those drills. Dead handy 😉
Bad bypass. Why would someone do that!?
I couldn't figure out a reason other than someone didn't have a clue what they were doing. I'm not sure why the previous plumbers that have been out and flushed the system several times didn't do a bit more investigation and figure out the problem. I was glad to as it gave me an excuse to buy a new toy, oops sorry I mean tool.
Nipped back this morning to finish off the pugging up outside and the customer greeted me with a big grin, it was the first time he had been warm downstairs in the winter since he moved in two years ago.
I had the same problem a couple months ago - a heating system from the 1960s had a 3/4" one pipe loop from the flow to the return immediately after the first rad.
I also fell for it, as the people were new owners & system hadn't been tested until I had been replacing some rads & pipework. Big relief when I found the bypass which had been to feed 2 previous rads on a 1 pipe loop (which would have always acted as a bypass). Felt good that I was the only guy that sorted it in 40 + years! :smile:
Some "plumbers" make the mistake of thinking a 2 pipe system must have both pipes joined for a loop, especially when they are capping off a rad for good & it is the last on a circuit.
Alex if you look good on that photo is not about the plastick fitting and the 450mm !!!! Is to do with the 22mm service valve mate !!!
To MJ : this looks to me as a ch return teed to the primary return
I got that. The 22 ISO has's been picked up straight away. I thought I mention more, cos the question was - "See anything wrong?" Only trying... Thank you SafeGasInstall.
umm, everything and all of it dont count, no where near right.... I want to see if you spot the not so obvious aswell as the obvious.
Also forgot to take a picture, but overflow from f and e went into the cwsc
Home made wonder i saw yesterday made me chuckle
And the other end
Voila ....a wonderful home made douche spray.
Don't know why I bother to stock chrome bottle traps. A bit of bubblewrap and a roll of baco-foil does the job nicely.
Snapped in the hotel in Taunton I was staying at over the weekend.
Barry98,
Harvest Fields,
