HALL of SHAME PHOTo`s
Cylinder change I did today.
The electrics had been bodged together and the 15mm vent pipe terminated above the tank lid so there was a lovely puddle on top of the tank.
What about the roof truss!!!! or lack of, I hope you lads don't do this if the tank won't fit, Jeez
the nuts for those terminals will be behind the cylinder ,not that i would ever do that after loosing the nuts
image.jpg I know it's not plumbing related but how about this for a bit of a quality workmanship. It's my daughters alleged kitchen, the crack in the plaster kept getting wider , think we know why !!!
It was defo a plumbing contractor for Barratt Homes… Competent or not, experienced or not, GSR or not, crash course GSR, a plumber, an apprentice, one of a rated people or checkatrade, a cowboy, a clown, a monkey or just some geezer with a van and tools.
:smile:
No... not this dude!
he's based in bradford see him all the time
Custard wanted me to change kitchen mixer. I said sure but only if I can change the rest of the pipe work too. Flexi hoses joined to flexi hoses! Magic. Custard declined re piping.
I would have said the same paul I think! no chance I would put my name to that you can more or less guarantee once you disturb the tap tails it will be like Niagara falls
Exactly when if your flue is leaking condensate is it ok to refix the flue clamp with silicone?
Maybe its around the same time your fitting placky pipe direct to an unvented cylinder.
Also It is a good thing you dont have to spend money on broken tundishes any more just pop a small funnel in the open end of d2.
Got to love rental property and their "maintenance men".
5 burner. Massive house I mean massive. Upstairs hallway was almost size of my living room. 20m long and 5m wide! His house was heated by 2 33kw COMBI boilers feeding six huge bathrooms. Bath shower sink and bidet in every one ...... 25mm mains. It was done by same pro who linked both boilers together with hep!
you have a living room 20m x5m!!
heated by a 600x400mm single 😛arty:
surely this never worked???
Riley,
Why not the water in the cistern is much higher than the connection of the sani-flow, I know you can't polish a turd but it will dissolve, be OK until
something big got in there and then go look for a plumber with a website who specialises in this sort of thingy!!!!
Barry98,
Harvest Fields,
