Okay had a call to a leak on a new installation last week. Repaired the leak but went back today to rectify the rest of the faults.
The job was a basin sat on a cupboard.
IMG_0107 by Mike Jackson1, on Flickr
When I say sat on, I mean sat on the basin had been placed on top of a piece of anti slip matting to hold it in place. Look at the amazing standard of workmanship where the waste hole is cut into the top. I may as well chuck my hole saws out.
IMG_0109 by Mike Jackson1, on Flickr
The waste was an amazing piece of work.
IMG_0101 by Mike Jackson1, on Flickr
When I took the waste pipe apart to run it properly I discovered how to join incompatible pipe sizes. I wish I'd known about this years ago, I could have saved a fortune on multifit connectors.
IMG_0110 by Mike Jackson1, on Flickr
This was the joint that was leaking. I had to open out the hole with the multimaster to get the armeg jawdropper on the bottom nut of the compression fitting. It really screams professionalism when someone uses a compression fitting when an endfeed one would be so much more appropriate.
IMG_0106 by Mike Jackson1, on Flickr
And a last view just showing the quality of the install.
IMG_0102 by Mike Jackson1, on Flickr
The customer has cancelled one cheque made out to the original "plumber" and is writing requesting he refund the cost of my remedial works.
Reactions: 8 people
Window fitters shouldn't fit bathrooms picture of toilet waste 20131127_112436.jpg
Reactions: 2 people
A monkey with a hammer would have made a better job....
a female iron is a female iron whether its got fixing lugs fitted to it or not
I was taught at college (I do question the tutors credibility to be fair) that gas female irons were tapered so if you screwed male in there would be a point of absolute closure
Whereas water female irons are parallel and the fitting does not taper inward.
He also said gas wing back fitting don't angle out from a wall they generally stay flush.
I stand humbly to be corrected I only know what I've been taught!!
I have had 2 x local plumbers send me the same pic.
One of them initially put my name forward to price the job, an old floor standing Rs boiler on gravity with a split coil in the cylinder.
Rather than do a full convert to fully pumped the chosen installer has just put a pump on the returns and told the old girl to turn off the rads when she does'nt want them on :smug2:.
He did raise the expansion tank tho, which he thought might help the split coil in the cylinder !!!!!
Sorry cant make out the model of the new boiler but can it be fitted under a work top ??
Raxi Solo !!
Ah the old he plus !
Yes to my own question it only needs 50 mm clearance at the bottom, fun emptying the condense drain then !
Next question What news paper was it ???
is the bit of aluminium a heat shield for when the paper gets going.?
V
UK Plumbers Forums
Deleted member 120897
