HALL of SHAME PHOTo`s
Yes the ufh is off the unvented Yes the installer was qualified. No he didn't have a clue. Yes it's hilarious and I can't help but laugh.
Qualified in what ???? it defo isn't plumbing (Water Regs or unvented), heating, electrical, lagging, even the woodworking skills aren't great it looks like they even ripped up the bit of flooring right next to the cylinder to use as the back board, you can see the screw holes along the edge of the T&G.
Some have absolutely no shame or then again perhaps they thought it was a good job.
Reg Prescott would have been proud of that!
He looked like him. One of our Subbies did it with a diyer / retired woodwork teacher ! Pair of morons. The ufh consisted of 49 loops of 10mm hep. No flow control or blending. Just on and off using boiler pump too...... F f s
Wow... Just, wow!!!
Still, should be a good earner putting it right... I take it the subbie is no longer a subbie for you?
not as stupid as it looks more reliable than cysten mates and less install cost then ir detectors some where that only gets used a couple of times a week its a great simple way done the same in a storage place and a church annexe
Just what I was thinking steve, and just incase any of you others were wondering if it is legal under the Water Reg's (cos I know how conceded & worried you lot get about such matters) it's fine. :hurray:
Could it be the sprinkler system water supply, but due to being on a meter rather than an uncontrolled expensive deluge of water, the occupier has to nip into the loft, flush the handle, this then discharges a controlled amount of water onto the fire thus saving the property and a huge water bill.
The clip on the 4 or 5 m flue is in wrong place so pulled flue 18d to vert turret goosed.
Wales and west had turned it off as CO detector kept going off. Flue in void. No access. BG had serviced it in April last year.
Service form said
flue safe no
Appliance safe to use yes
Sand in condense trap and flue. God knows whats happened to the terminal as no access
Barry98,
Harvest Fields,
