Has my builder ruined my boiler?
View the thread, titled "Has my builder ruined my boiler?" which is posted in Boiler Advice Forum on UK Plumbers Forums.
If the cold water feed to the filler loop is boiler side of the new valves you should be able to pressurise the system. It's unclear what's where from the pictures. It needs a sketch of the pipework with valve positions. If you turn a tap into you get hot water? Too much guesswork without a diagram.
The manual for the boiler clearly says the the diverter valve needs to be open to fill.
Get someone out to check it?
No point any of us guessing as by the sounds of it you shouldn’t be touching it anyway.
Regardless looking at your pictures you don’t have a bypass for when both zones are closed. Who knows if you’ve got a non return anywhere on the system.
You’ve also got a combi so hot water demand isn’t with the zone valve.
You’ll need a professional to diagnose on site it in my opinion.
Reply to the thread, titled "Has my builder ruined my boiler?" which is posted in Boiler Advice Forum on Plumbers Forums.
Thread starter
Joined
DIY or Homeowner
Thread Information
Title
Prefix
N/A
Forum
Boiler Advice Forum
Start date
Last reply date
Thread Tags
Tags Tags
boiler
windle poones,
Karl Murray,
