The emphasis being "plumber" or heating engineer !
If you read the manual it says the diverter valve needs to be be open to fill. There doesn't appear to be anything wrong with the work tats been done.
If the cold water feed to the filler loop is boiler side of the new valves you should be able to pressurise the system. It's unclear what's where from the pictures. It needs a sketch of the pipework with valve positions. If you turn a tap into you get hot water? Too much guesswork without a diagram.
Reply to the thread, titled "Has my builder ruined my boiler?" which is posted in Boiler Advice Forum on Plumbers Forums.
