Jan 24, 2017
hi there
firstly i would like to ask croppie not to close my thread again, i am a gas safe engineer, (number available if required)
i just need some advice on this boiler please as there is no details on the heatline site.
i have a boiler that started to go wrong a short while ago and a plumber came out to look at it and told me that the diverter valve was leaking and had blown the three way valve motor, he replaced the motor unit and then cut the cable powering it and connected a new one, i still have the same problem that it is blowing fuses, i suspect that he has wired the plug that goes into the motor wrong,
does any one have the connections on the motor unit, they are labeled 1,2,3 but i need to know which one is neutral and which one is poss for heating and poss for water.
all i am looking for is the electrical connections, and before you ask yes i am also a napit registered electrician
hope to hear soon
may i ask if your gas safe reg why you would get another gas safe engy to fix your own boiler
if you are truly gas safe
get your post count upto 10 (non spamming)
the once you have pm croppie for more info
M
Boiler Advice Forum
Deleted member 120897
