Hello again all, one more question regarding a flexible pipe, Thanks in Advance (pictures attached)
View the thread, titled "Hello again all, one more question regarding a flexible pipe, Thanks in Advance (pictures attached)" which is posted in The Welcome Wagon :) on UK Plumbers Forums.
Good Morning again,
I appreciate the advice some of you gave yesterday regarding a soil pipe fitting.
I do however have one more question and it relates to the size of compression fittings. I have been given this flexible hose that came as part of a new toilet, there was a customer like isolation valve which then attached to a 15mm pipe. Unfortunately, the original part has been lost and I need to find a new one.
It seems as though the internal thread of this unit sits at approximately 15mm or almost at 5/8ths, the external diameter is 20mm and just over 3/4inch.
I need to replace the fitting that connected the end of this flexi hose to an isolator that will go to a 15mm pipe, It would be great if anyone could recommend something.
I have attached pictures for clarity.
Thanks in advance.
Rhys
I’m not entirely sure I follow what you want. Are you wanting something to connect onto this flexi, are you wanting an isolation valve or both?
I basically need an isolation valve that will be the union between the Flexi pipe and a 15mm mains pipe. The other end of the Flexi pipe will be connected to the toilet.
Sorry for the confusion
I’d go for this:
https://www.NoLinkingToThis/p/full-...s5wwAJz3JILOOBjB_z4aAqUAEALw_wcB&gclsrc=aw.ds
The nuts should be 1/2”, there’s a risk it’s 3/8, but try by screwing onto the toilet inlet trying both ends.
That looks like a supply pipe that you would get in the likes of a concealed cistern. To connect the isolator to the inlet valve. I had a grohe one to fit like that before chrustmas.
One end will go into the fill valve
the other end looks like a filling loop valve
eg
https://www.NoLinkingToThis/p/r24-filling-loop/83905
Use the long valve as that has a double check valve in
I’m not 100% on this but should that be able to connect directly to a 15mm lever valve? Pretty sure it’d fit.
Reply to the thread, titled "Hello again all, one more question regarding a flexible pipe, Thanks in Advance (pictures attached)" which is posted in The Welcome Wagon :) on Plumbers Forums.
Octoply,
Timmy D,
