Help finding pipe diameter fittings
View the thread, titled "Help finding pipe diameter fittings" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi
Could someone help please. I live in an old house and I'm refurbishin the bathroom, the mains water connection is an odd size and need to convert to 15mm pipe. I have tried 22mm pipe too big and tried 20mm pipe too small, I have been reading up and I think it's 3/4 imperial pipe so about 21mm outside diameter. Is there a fitting which I can screw directly to the male thread on the mains pipe to 15mm compression? This is proper stressing me out. Also would the mains pipe go down and out of the building rather then follow the wall on the inside of building
Reply to the thread, titled "Help finding pipe diameter fittings" which is posted in UK Plumbers Forums on Plumbers Forums.
Batters167,
Timmy D,
