help me grow
View the thread, titled "help me grow" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Haven't read most of the posts, though bob on work. Id say your better than 95% of heating engineers. Full stop!
Of course im in the top 5%.
I'm with the others on keeping the pipes parallel down the wall and bringing them in and crossing about further down. I used to fixate on using pulled bends to reduce resistance but most combi pumps are well over the top for the systems they are in and endfeed bends don't cause any problem.
With the condense I would have come down from the condensure, used a 90 and put a kick on the pipe with my bender and crossed across in front of the other pipework and used a 90 down into the 1 1/4. To achieve an air gap, rather than use a separate upstand I would just have put the overflow into the 1 1/4 without a fitting.
Obviously I would also have used a decent boiler other than the Worcester.
Not read all the posts so sorry if I'm repeating. Looks like a very tidy install mate. Is it one of your first ones? Looks good. Does it work?! Is customer happy? I'd be proud of yourself! (Apart from the big dirty Worcester thing!)
thanks mike and app, first one solo without anyone else. usually i get told where to put the pipes !!!
customer is happy 🙂
the next door neighbour has just had a look and asked why the 40mm pipe and not just use the 21.5mm outide.
explained about the freezing issues
she asked me to pop round and look at hers.
vailliant with the same position and run....in 21.5mm installed this summer.
horizontal run has no fall to it.
if welsh women are anything like scottish women, i wouldn't want to be her installer right about......... now !!!
Flue has slight fall built into it. Outlet it at top outside and in center at boiler. If it's less than 1m there is 2.5% fall so don't worry. 21.5 outside is standard practice , 32 and insulation won't fit on saddle bag!
Here's that install I finished up yesterday, first intergas install. No particular skill either, just a boiler and some straight pipes.
21.5 on a 7m external run 🙂 i think it's gonna be an issue !!
Not on the newer worcester flues I'm sure? The outlet is central, the older kits with the long terminal had a built in fall, as do the vaillants.
that wasn't the intended boiler position, walked in the door and they changed their minds !!! made do with a small extension 🙂
it looks better than some of the shyt ive fitted in the past. 🙂
i would do as other have suggested and keep your pipework straight down. It helps it look neater, it helps you get your spanner on stuff, its easier to lagg the cold, and other pipework. If you have to cross alot over at the bottom of a cupboard or come out the floor in the middle of the cupobard due to floor structure then i sometimes drop a false floor in to make it look neat and save time altering the existing pipes.
keep up the good work!
Neat job.
They gonna struggle removing that wallpaper now though....😀
yeah I thought that, but then realised I didn't care.
I did wonder why it wasn't all taken off before the boiler was fitted, the boxing to the right was removed prior to me starting.
Looks good Billy.
There's always things we would like to do differently or aren't happy with. I hardly ever look at my work and think it looks great. I always pick up on what I'm not happy with.
It doesn't help looking at some of the work on Facebook and here. Which is top or the class good, and they've obviously had time to think about it.
On the whole, I think it looks good. The condense with all the 45's is the only thing that draws the eye. Well done mate.
Part the way through gas training.....wouldn't that compartment require high/low level ventilation <5 m3 ?
We were told MI exceed anything else....but I'm 99.9% sure it was across the board as a general to do with high/low level vent. That was my understanding of what we were told.
Nice job. Cant say I have much to add over the more experienced comments that have allready been made. I agree it looks congested. Is the system big enough to need the additional ev or is it back up, im sure a read a post of yours that mentioned doing that. Are the 22clips spaced off the wall To allow the 15's to pass behind? I would be pleased with such tidy work.
With room sealed boilers, vents serve only to dissipate heat as not required for combustion. The mi's for the boiler shown dont require them wich makes sense as most modern room sealed boilers are in essence appliances within there own compartment (casing) which is ventilated by the fan drawing fresh air through the concentric flue in to the inner boiler casing.
my gas, flow and return come into that run of the joists but my hot and cold came from the left, i didnt want to cross them over high so i chose to do it low 🙂 i'm sat here looking at it now thinking of how it would look good with all your snippits of advice !!!!!!
next time, you do better next time 😉
It says;
Note
It is no longer permissible to utilize a non-thermostatic controlled radiator as a by-pass.
So I fitted one.
Without trying to hijack this thread king, heres one I did today with cross overs at the bottom. The gas came out the floor in a silly spot but it was an LPG park home so wasnt going to mess around with it underneath.
Sorry about the Worcester, was a sub contract job.
It looked a bit better in the flesh I thought, looks a bit busy in the photo but you get the idea, sort the pipes out ASAP then continue up the wall straight.
Notice all toss bonded excluding the gas? I hate a tidy job. Much better to have pipes all over under boiler IMHO, make u feel less self aware!
Reply to the thread, titled "help me grow" which is posted in UK Plumbers Forums on Plumbers Forums.
Killy Bing,
Leo21,
