There are times when i've went to a job that i done 30 odd years ago and thought, fk you were good :lol:
the next door neighbour has just had a look and asked why the 40mm pipe and not just use the 21.5mm outide.
explained about the freezing issues
she asked me to pop round and look at hers.
vailliant with the same position and run....in 21.5mm installed this summer.
horizontal run has no fall to it.
if welsh women are anything like scottish women, i wouldn't want to be her installer right about......... now !!!
Flue has slight fall built into it. Outlet it at top outside and in center at boiler. If it's less than 1m there is 2.5% fall so don't worry. 21.5 outside is standard practice , 32 and insulation won't fit on saddle bag!
21.5 on a 7m external run 🙂 i think it's gonna be an issue !!
Here's that install I finished up yesterday, first intergas install. No particular skill either, just a boiler and some straight pipes.
Neat job.
They gonna struggle removing that wallpaper now though....😀
yeah I thought that, but then realised I didn't care.
I did wonder why it wasn't all taken off before the boiler was fitted, the boxing to the right was removed prior to me starting.
Part the way through gas training.....wouldn't that compartment require high/low level ventilation <5 m3 ?Here's that install I finished up yesterday, first intergas install. No particular skill either, just a boiler and some straight pipes.
We were told MI exceed anything else....but I'm 99.9% sure it was across the board as a general to do with high/low level vent. That was my understanding of what we were told.
Why the auto bypass?
Believe it says "maybe required".Required in the MI mate
my gas, flow and return come into that run of the joists but my hot and cold came from the left, i didnt want to cross them over high so i chose to do it low 🙂 i'm sat here looking at it now thinking of how it would look good with all your snippits of advice !!!!!!
It says;
Note
It is no longer permissible to utilize a non-thermostatic controlled radiator as a by-pass.
So I fitted one.
Reply to the thread, titled "help me grow" which is posted in UK Plumbers Forums on Plumbers Forums.
