Jun 9, 2014
Grateful for all advice. Our property is 12 years old. My wife is getting agitated about a strange smell in our en-suite bathroom near to our close fitted toilet bowl. There are no leaks. I have checked the traps on the bath, bidet, shower and wash-basin. They all seem fine. The soil pipe is internal with an AAV in the eaves. I haven't been up to check this as I am probably a bit too old for climbing into lofts. I have removed the drain cover and waste water is flowing. There are no strangle gurgles when the toilet is flushed or bath etc emptied.
The only work that has been carried out in the past few months is a replacement toilet bowl - the original one wasn't glazed properly and it became discoloured in use. I do not know whether the plumber used a new push in connector. I am clutching at straws here but is it possible for the connector to leak air but not leak water. I am thinking perhaps of a small leak/gap on the upper surface or the connector/soil pipe.
Anything else I should check?
The pan connectors do sometimes leak air and not water on the upper part. Can you get at it to put some duck tape round to see if that cures it?
Thanks. The front edge of the connector is covered by the sides of the pan. I am just going to have the plumber back to check it.
when ever you change, remove and refit a toilet you need to change the pan connector as the rubber will be worn(stretched, out of shape). it is possible that may be your problem if the old one was used for the new toilet?
it would be better to replace it, but for a quick fix as you have no water leaks a small amount of sillicone around the gap between the pan and connector should do it, prob will have to use a finger. have some hand wipes and tissue ready.
Thanks to everyone. The forward face of the connector is just not accessible as it is protected by the toilet sides. I have e-mailed the plumber who did the fitting 6 months ago and asked him to check his work. I will post again with the outcome.
Update. The plumber came last week and he identified the problem as a leaking 32mm water supply pipe gasket where it is pushed into the back of the close fitting bowl. The plumber replaced the gasket and went away. Unfortunately, he hasn't fixed the problem as the floor under the toilet bowl is damp again. I have therefore wiped everything down and packed paper towel under the water supply pipe. The pipe/gasket is still leaking from one side. The paper is holding the slight leak and the smell has gone away as the floor/carpet have dried out.
The problem (as far as I can tell) is that the 32mm cistern water supply pipe is not exactly perpendicular to the back of the new toilet bowl. Dare I suggest to the plumber (as he is coming back again tomorrow) is that the easiest way to solve this problem is to cut the pipe and insert a flexible connector? Is there such a thing? I should add that the cistern overflow pipe is connected to this pipe with a plastic/glued 'T" junction.
I am getting the impression that the plumber was hoping for a quick fix.
