Feb 28, 2018
Bolton
DIY or Homeowner
First of all I know nothing about plumbing I apologise for any errors. This is for connecting mains water to a caravan.
I need to link a black 28mm (pvc?) mains water pipe that cannot be pulled up or replaced into a 25mm mdpe pipe.
The 25mm connects to 15mm in the caravan, so the 25mm could potentially be changed but I can’t find any fittings for 20mm or 32mm either.
So I have searched for a 28mm - 25mm reducing tee to no luck also tried an equal tee to a straight reducer and found nothing.
I’ve rang every plumbers merchant in the county please can someone help with either the correct fitting or a working alternative.
Thank you!!
Well the black pipe you have could be Alkathine old imperial size what you need to do is cut off a small pice take it into your local plumbers merchants they should be able to sort it out for you
I’ve been to my local plumbers merchant and asked for a 3/4” to 25mm reducing tee and she got me the right product so my problem is solved thank you so much I’d been banging my head for days!
  • Friendly
Reactions: jtsplumbing
