help with powerflush quote
View the thread, titled "help with powerflush quote" which is posted in UK Plumbers Forums on UK Plumbers Forums.
also, the parking each day will be £37. so am going to go with mfgs and go for £900. Thanks guys, wish me luck. Should be a nice £350 a day
300 for 0-10, 350 for 10-20, above 20. Is different. Regardless of system or single or double rads, there aint much difference between singles and doubles, you can't remove one panel from the other panel!!
Is that in Knightsbridge though?
15mins a rad seems short to me, it feels like forever waiting for the tds readings to drop.
i know a lad who powerflushes at an average price between £180 - £250, he does 6-7 a week most of the time and loves it. I dont think hes Gas safe tho so i dont know how he goes about removing the plate hex or attaching to pump in most HE boilers?
i think id price £7-800 with a filter, 2 days work.
I use Kamco CF90, I would still charge £350, customer happy, I may get more work and I sleep at night. Even charging £350 I still make way over my usual day rate including chemicals and fuel. The way I see it is don't think about what you could make but think about what you are making. so for instance if I am quiet I will labour for a friend for £50, which is better then staying at home and earning nothing. If I quote £900 because BG quoted £1400, I may loose that job even. so £350 is better then nothing. If somebody offered me £20 quid for a days labour, I would take it, because its better then earning nothing. As things change and I am too busy, then my prices will go up and I will stick to plumbing only, but at the moment beggars cant be choosers.
That's 15 minutes on the initial flush not the cleaning out process. Kamco recommend 15 minutes. 15 minutes on the initial then go round and clean each rad until it runs clear. (not misty) I need to invest in the TDS meter
add the chemicals 2 x cleaner, 2 x inhibitor. and 2 days labour, add fuel plus £60 towards power flush/ rental and there's your price
With 16 double rads you're not putting enough inhibitor in. Recommendation is 1 bottle does ten single rads so for 16 doubles you're going to want 3 or 4..
Ignoring that looking at your price of £350 take off £60 for hire of machine gives us £290. 4 bottles of fluid, £60, we're down to £230. Two days parking, £74, were looking at £156. Lets be miserly and allow £6 for fuel. That gives us £150 for 2 days labour. Do you really work for £75 a day?
looks like i might get this job. think i should buy a machine now. debating between proflush themea or kamco cf90? Leaning more towards the proflush. llike the heater part
cannot find them 2nd hand at all. cannot actually find a price unless i contact the manufacturer. anyone got a proflush they want to sell???:smile:
Already got machine so wouldn't pay £60 for machine, definetly wouldn't pay £74 for parking, if they want me to do it then they get me a visitors permit and it wouldn't take me 2 days, I would get there at 7.30am and finish at 7-8pm. so total cost is £60 chemicals, £6 fuel, so still making £284 for a long days labour. If I lived in London and had congestion charge, parking etc then my price would go up, but then I expect everyone else in London charges more.
Thanks roger, can you tell me a rough price for these? as i cannot see it any where. looks like it is only the manufacturer who sells them and no price is on the website
Got proflush with heater. Its a good machine but where possible i use the heat from a working boiler and the magnacleanse in tandem.
The heater takes a good while to heat up on its own but the flusher is a great machine but larger than most others
Make your mind up. You said it was two days work in another post. Even if you can squeeze a two day job into one day you should still charge two days money for it, it's you that's going home knackered for the benefit of the customer. you've also got the issue of being cream crackered the next day after a 12 hour day. You can't keep doing 12 hour days without it starting to affect your performance.
What happens when your powerflush machine packs up after you've been not charging for it's use? You've got to replace or repair it out of your own pocket.
IMHO you need to revisit your business model as it sounds to me you're heading towards being a busy fool. Work for a good price and work sensibly. I've done the 12 hour days, 6 days a week before and I'd then spend half of Sunday akip on the sofa because I was knackered. Don't live to work, work to live.
By your plan, would you do a boiler change the same way....in a long day for say £250-300 ? Labour only....
business costs are sometimes hard to account for but need to be considerd for each job. Van costs are many thousands a year alone.
equipment cost need to be factor'd in wether you have rented or brought as it will need replacing or repairing as you go. If you add up the costs of stuff like the machine, hoses and fittings, pump/plate hex adaptors, magnetic filter, tds meter, ph meter, infra red thermo etc.... its very expensive.
can somebody tell me how non gas safe registerd engineers attach there machines without removing the appliance covers on HE models?? Many of these deadicated power flush companies dont employ GSR's from what i can see. The guy who started the biggest national company was not even a plumber.
Everyone I know does!!! start at 8am and finnish at 5-6pm, straight swaps, don't know there prices though!!
i agree its pretty standard to do boiler changes in a day, straight swaps in a few hours sometimes, tho its also standard for them not to be done as good as they should be imo. Especially landlord/council work. In the end the customer will get what they pay for most times.
simple connect to pump on regular boilers or connect to flow or return on combi boiler just underneath, no cover taken off. to be honest though, most combi's I have done they have had a magnaclean fitted so I drain down and connect to this, then just turn magnaclean iso's off and then put magnaclean on.
so you dont flush the boiler or the plate hex?
I said he should charge 2 days, but I would do it in a day. Even with charging £350, I am left with £280 which equals £60 for power flush and still leaves me £220 which is good for a days labour. and if I added my years power flushes together and took times that by £20 I would get the price of my power flush machine. I am actually looking at my business model and I will be changing things but I would rather be a busy fool then a poor fool.
Yes, flush the boiler as you go, connect to the return and it pushes it all out the boiler rather then into the boiler. The heat exchange is impossible unless you are Gas safe, except to turn on the hot water and let the boiler pump do the flush and then turn it off, do this several times when cleaning out, doesn't do it properly though
the proflush i just bought said the best method of attaching is on the radiator tails, as if you remove the circulating pump, the boiler wont work
Boiler not working, if you take the pump out it will still work but will overheat if power flush isn't connected, connecting to the tails gives less flow rates and from my experience doesn't do the job as well.
sitting at home waiting for the delivery of my Norstrom proflush. So excited. A new tool!!!!
Cost me £1100 big ones howsie!!! Am still upset I missed out on eco's which you got. On my door step. Still, this job pays for it pretty much. And it comes with a 3yr warranty
Reply to the thread, titled "help with powerflush quote" which is posted in UK Plumbers Forums on Plumbers Forums.
mutley racers,
jase158,
