Help with unvented cylinders central heating
View the thread, titled "Help with unvented cylinders central heating" which is posted in Central Heating Forum on UK Plumbers Forums.
Tbh. Something massively wrong if one of the relief valves are passing that amount. I bet the standard ones can't take that either.
Done my unvented in the end so all qualed now however, before my course i rang gas safe who can advise on building reg G3 who said that as long as your not installing an unvented cylinder, then it is completly fine to work on it and change components!!! This is how companies get around it......although the instrucror on the course said they are talking Rubbish!!! Very grey! Non the less i have the qual now
Your tutor is correct
If gas safes logic transfers that means you can repair gas appliance eg boilers without needing to be qualified
So all hot water installations are notifiable...
unless testing and adjustment is not possible, or would not affect the energy efficiency of the fixed building service
Surely, then, that would apply to a normal, old fashioned, DHW cylinder? What can I adjust and test except the thermostat? The main energy efficiency (seeing as the cylinder always comes pre-insulated) would be in the proper horizontal run before the vent and the pipe lagging; the safety lies in the design of pipework. Both of which would be 'tested' by visual inspection, certainly not 'adjusted' in any way.
If I'm wrong, of course, then this makes a mockery of the C&G level 2 assessment in which you must design, install, and remove a hot water cylinder and header tank?
Reply to the thread, titled "Help with unvented cylinders central heating" which is posted in Central Heating Forum on Plumbers Forums.
Adam Perry,
Ric2013,
