Hints, tips & secrets of plumbing - No Banter please!
View the thread, titled "Hints, tips & secrets of plumbing - No Banter please!" which is posted in UK Plumbers Forums on UK Plumbers Forums.
re: Hints, tips & secrets of plumbing - No Banter please!
I'll second it that pushfit and chrome plated pipe is a disaster waiting to happen. Even with compression joints I rub the chrome off the part where the olive grips. As I've known the chrome plating to hairline crack and then the joint to drip.
Easiest way I've found is the use rough grade emery cloth, a long strip and just back and forth it around the pipe. Best place for emery cloth is Toolstation.
Right, back to work!!
Got emery cloth and rothenberger strips in the van and to cap it I had them there when I did this job...feel such a fool now...still Thanks for the knowledge, it all makes for a better tradesman.....
Oh well thanks, the other night it was late and I only had a pushfit and a chrome elbow left whilst fitting a bathroom radiator.....looks like I need to go round and freeze it and then change it for a comp 90....
Thanks for the advice, looks like this may have saved me a BIG issue.....
If you ever have to do it temporary (you shouldn't) wedge the fitting onto the pipe so there is no room for it to blow off.
i've just realised the first ever tip on this thread was about not putting pushfits on chromed copper pipe lol.
Always remember to put your nut onto the oil pipe before you flare the end over
Thanks for the advise, i did re-visit the job froze the pipe and swopped the fitting ect filed the pipe down ect, the customer is my mates father in law. This morning the cheeky beggar rings up telling ME my bill was to high.........No Call Out was charged, anyhow apparantly that's standard practice for this Joey.....You can't win em all........No further discount was given i can assure you of that! lol
Use pipe lagging?.... come on then dont keep it a secret.
Hints, tips & secrets of plumbing.
I hope your a supporter. It ain't free to advertise here
your right there simon ,thanks
In instances of using fischer fixing bolt kits for basins if its in a job spec or its your preference, I use a standard drill on a non hammer drill setting. Place the bolt in the chuck threaded side (but not torqued up to the hilt so you dont damage the threads even though this has never been a problem for me) and use the drill to wind the bolt in to either the plug or straight into the timber patras in situations where its a boarded wall and its zaps the bolt in quick and with little effort. Once secured in the wall a quick turn on the chuck to loosen it and pop the drill off. Bolts in the wall secure fast and easy with little effort.
Just find it saves me time and saves me using an adjustable winding it in by hand slowly and I have used this menthod many times without a problem.
Funny you should mention that! Ive been locking socket sets they look like the mutts and my tool arsenal seriously lacks a decent set of socket tools.
I have just looked at similar Teng 1/4" socket sets & they are a lot cheaper (under £40) & seem top stuff. My brother has a couple of Teng sets & very impressive.
ive got the teng set on the van
Ive got the halfords set that costs about £100, not cheap but its got alot in it and has never let me down.
I phone torch APP 🙂 brilliant if your batteries have gone dead on your torch or head torch. Works perfect
especially if you hate talking to customers on the phone and dont want any more work and your more than happy with a flat mobile battery in about half an hour
How do you use pipe lagging to get rid of air locks ??
i guess you get a piece that hasn't been cut along it's length and as long as you have seperate taps and not a mixer, you can connect the cold and hot together and use your third hand to turn the taps on forcing the cold mains up the hot forcing out any air locks.
Third hand...yes that and a trick foot are perhaps the biggest help in this game 🙂
I normaly use a washing machine hose to get shot of airlocks, either end coupled up to the hot and cold on the valves and a quick blast through. A lad i used to graft with had a small tube with two rubber fittings that wraped round the outlet of taps.... like those naff shower hoses you could buy that hooks to a hot and cold tap on your bath except this didnt have the outlet for the shower. ive never seen any of them about though, was a very handy method, they just pushed on and pulled off once the airlock was sorted.
When there's no drain offs I keep 1 of them self cutting taps handy that come with the DIY outside tap kits, strap it to abit of 15mm and away you go! Then while the system is drained just cut a tee in with a drain off where the hole is from the self cutting tap.
We've had that one a couple of times now. 🙂
Thought so, didn't fancy going through 28 pages to check though lol 🙂.
Just didn't have time to go through the whole thread 😉. Never mind eh
That's a shame because there's a tip in there somewhere that will save you hours and make you a fortune.
Reply to the thread, titled "Hints, tips & secrets of plumbing - No Banter please!" which is posted in UK Plumbers Forums on Plumbers Forums.
REDSAW,
firemant,
