Hints, tips & secrets of plumbing - No Banter please!
View the thread, titled "Hints, tips & secrets of plumbing - No Banter please!" which is posted in UK Plumbers Forums on UK Plumbers Forums.
re: Hints, tips & secrets of plumbing - No Banter please!
i guess you get a piece that hasn't been cut along it's length and as long as you have seperate taps and not a mixer, you can connect the cold and hot together and use your third hand to turn the taps on forcing the cold mains up the hot forcing out any air locks.
Third hand...yes that and a trick foot are perhaps the biggest help in this game 🙂
I normaly use a washing machine hose to get shot of airlocks, either end coupled up to the hot and cold on the valves and a quick blast through. A lad i used to graft with had a small tube with two rubber fittings that wraped round the outlet of taps.... like those naff shower hoses you could buy that hooks to a hot and cold tap on your bath except this didnt have the outlet for the shower. ive never seen any of them about though, was a very handy method, they just pushed on and pulled off once the airlock was sorted.
Hints, tips & secrets of plumbing.
When there's no drain offs I keep 1 of them self cutting taps handy that come with the DIY outside tap kits, strap it to abit of 15mm and away you go! Then while the system is drained just cut a tee in with a drain off where the hole is from the self cutting tap.
We've had that one a couple of times now. 🙂
Thought so, didn't fancy going through 28 pages to check though lol 🙂.
Just didn't have time to go through the whole thread 😉. Never mind eh
That's a shame because there's a tip in there somewhere that will save you hours and make you a fortune.
Like keep out the bookies and there is no such thing as a certainty :wink:
Don't eat yellow snow!
5p and washer in a nut makes a 15 cap end
Might have been mentioned before but different makes have slightly different size of 22mm overflow pipe. If you find your pipe won't go into a fitting, warm it up slightly with your torch and push it in. Likewise if you find it a bit slack for the fitting, warm it up and stretch it over a 22mm bending spring.
Here's one, Been doing it for years.
Stupid sized chrome waste pipe, wrap insulation tape around the end until you build. It upto 1"1/4 and then you can solvent weld it. Saves messing about with mcalpine fittings in walls etc.
every one plumber should have a land rover to be able to go out when all others can not
i know it has been said before but just found out my self ,so
This is a new one to me.....so what you're saying is the insulation tape will melt with the solvent glue and you get a decent watertight joint with it? How on earth this you discover this? Does it really work, I take it you've had no problems with it?
This may come in handy, and I'm gonna have to try it myself.
Not necessary. There's been loads of discussions about it on here, have a search.
Reply to the thread, titled "Hints, tips & secrets of plumbing - No Banter please!" which is posted in UK Plumbers Forums on Plumbers Forums.
REDSAW,
firemant,
