Hints, tips & secrets of plumbing - No Banter please!
View the thread, titled "Hints, tips & secrets of plumbing - No Banter please!" which is posted in UK Plumbers Forums on UK Plumbers Forums.
This is a great tip! Although I'm not sure why you'd need ptfe on cylinder unions.
There is the odd occasion when you can't get the standard cylinder unions on and this could be handy (I used to do it). Most of the time now I use stainless steel cylinders which come with compression fittings already in place.
Must be a regional thing, I've always been taught to use female irons on cylinders and that is what I'm given by the merchants when I ask for the fittings for one.
i have to admit aswell for years i used FI on cylinders, normally got them in fittings packs from the company i was working for. I do use the proper unions now.
I haven't fitted a vented cylinder for a few years.
I've changed the odd one that's split, and they normally have FI fittings on em if my memory is right.
Well there you go! Apologies for the slight!
I am sure when I compared cylinder coil fittings to Fi's the Fi's were cheaper.
Just checked plumbfix prices and 22 x 1"FI is exactly the same price as 22 x 1" cylinder unions.
I find cylinder unions quicker to use as there is no faffing about with tape though. Just a wee smear of jet blue.
Keep a pair of old 15mm and a pair of old Belmont type radiator valves in your van so if you are taking a radiator off without draining the system you can whack them on the radiator when disconnected so you don't drip black water around when you take it outside.
Any chance of a pic to help us see what you mean.
Just checked plumb c. £3.80 for Fi £4.43 for cyl.union in EF.
Close the valves to keep the water in the system, undo the valves off the radiator and swap for your old ones, keeps the water in the radiator without having to rely on putting your thumbs over the holes!
Turn the radiator upside down ! But make sure bleed screw is closed !
Or as I said a few weeks ago
When removing rads:
(Assuming you've prepared the system appropriately and have your old towels under the valves etc)..
Have a couple of male compression caps at hand (1/2 or 3/4 dependng) and, once the rad is undone from the valve, gently separate and lob the cap in between, then do your rad-side nut up. No need to drain inside the house, no leakage, just carry outside and empty there. (obviously this will make the rad heavier so this will only work if its a smallish rad, or if there are 2 of you, or if you look like Croppie and can lift one in each hand...🙂)
Read more: http://www.ukplumbersforums.co.uk/p...umbing-no-banter-please-45.html#ixzz2PFZTWmMG
:37:
just crack the rad nut and use you wet n dry to suck up the rad contents, flick rad upside down and walk it out. No spills, no mess, no doing your back in! simples
Thanks for the heads up Danny. Bought one today. Thanks to mike for the idea too 2013-04-02 16.04.02.jpg
I knew you'd all catch on eventually. You should have a non return and isolator on them really though folks.
P.s. this sprayer is about £6 at stax.
is this quicker than drainging a small amount of water from a towel rail, then topping up with chemicals??
invest in a listening stick, can help locate partial blockages. open all lockshields and trvs etc full then go round accessible pipework putting the stick on it. you usually get louder velocity noise in the local of a restriction.
pls post a link
Reply to the thread, titled "Hints, tips & secrets of plumbing - No Banter please!" which is posted in UK Plumbers Forums on Plumbers Forums.
REDSAW,
firemant,
