Hints, tips & secrets of plumbing - No Banter please!
View the thread, titled "Hints, tips & secrets of plumbing - No Banter please!" which is posted in UK Plumbers Forums on UK Plumbers Forums.
That doesn't work if you suffer from short term memory....
Get home find the spare in your pocket and sh.. Yourself😀
I did that once. I found a test point screw in the bottom of a meter box. Someone must have dropped one previously. I stuck it in my pocket and forgot all about it. I stuck my hand in my pocket next morning whilst in plumb center and turned white when I felt it. It was a moment or two before I remembered picking it up. i puckered so much they needed a drain rod to remove my undercrackers from my behind.
DIY radiator vibrator. Not having a lightweight drill with a rotary stop, I wanted to use hammer action of Hilti TE2 to assist power flush. Solution:- Take piece of hardwood, ( I used beech offcut of old table leg) , Drill 13mm hole 3mm deep and insert small steel washer. Use blunt short stem 12mm masonry bit in drill. Washer centralizes drill bit while at the same time allows rotation and prevents penetration of wood. Of course if you have a rotary stop and a diamond core set, then the 1/2"BSP to SDS adapter can be end capped with a standard fitting, use hole saw to produce suitable size discs from the wife's plastic chopping board, super glue to fitting and for the price of a new chopping board,(optional), you have a solution at a fraction of the price of some well known products.
Use the top item to make the bottom one and use it to hold the ring clip things open. Like the ones on the radiator hoses in your car engine.
Keep these from old mixer taps. Come in handy when a customer wants to reuse old taps or the one with a new tap struggles to fit etc
Useful boiler tip. Check gas meter to see if a) is a pre-payment or not & b) if its got credit if it is. Spent ages wondering why a boiler wouldn't fire up only to find credit was finished. Doh!
Pick up the red elastic bands that the Posties love discarding all over the streets, and pop a few in your cordless drill case. When your drill battery dies if you can't put it straight on charge, put a band round it to show its a deadun. Next time you open the case you'll know which needs to go straight on the charger.
One of my mates bought a similar one that are designed for keyboards and similar applications, and he found out the hard way, luckily no serious damage was done. They are usually cheaper than the air dusters for gas applications. Moral of the story cheapest is not always the best.
This may seem obvious to some but it took me a couple of installs to work it out.
Drill the tap holes in a bath and do the pipe work but don't fit taps until the end when you've done your silicone. Looks way better than the feeble attempt of sealing behind the taps with little room.
Can't always be don't this way but when it can its worth doing!!
never leave a full bundle of 22 in a un ocupied house over night! no matter if they have an alarm or not! i never leave tools and dont usualy leave any materials that arnt fixed but i was allready soaked wet through and couldnt be botherd making another trip!! another lesson learned get wetter and save money!
Good job you didn't leave your kit aswel then mate.
i once had all my gear taken down to the old knackerd tools you put in the spare bag "just incase" so now i never leave anything first time i have left anything since the last time and its gon again! worst thing is it will most likely become scrap!! not even used propperly!
A dermel and their little slitting discs have saved the day for me when trying to remove seized pump nuts with tight access. Slice a little slit in the nut and use a chisel to spread it.
I keep my 3 babies (18v makita drill, 240v makita angle grinder , 240v jigsaw) in a spanner bag. They don't stay in the van, ever. Also nobody sees the big branded box. It's easier to carry them. And even the people on my street don't know what's in the bag. It works for me
dont know if its been mentioned before but, when drilling with a long drill bit from inside of property to outside , mark the bit with insulating tape so you know when to turn hammer action off sds when your abou 1/2" from the outside , this prevents exploding the plaster off external wall!!!! belive me it does work!!!
Get one of these!
Best buys I have made in a long time!
It eats up joists, plastic pipe, battens and the like. Put a demolition blade in and off you go all day long . . . .
You can even use it like a jigsaw - the fun never ends!!!
When I was installing some Hardybacker board this beauty was one of the only tools up to the task!
Still I would upgrade to the bigger batteries soon as it really does cain the small (1.3ah) ones.
Reply to the thread, titled "Hints, tips & secrets of plumbing - No Banter please!" which is posted in UK Plumbers Forums on Plumbers Forums.
REDSAW,
firemant,
