Nov 5, 2018
DIY or Homeowner
So had a water leak in the pipes above the ceiling in the hallway and below the floor in the landing.
Called home insurance who sent home emergency team which is run by Homeserve.
They put a hole in the ceiling and found the leak, but the pipes were so high up close to the floor above we had to take up the wood flooring on the landing so they could cut a hole in the landing floor.
Leak was caused because the hot and cold pipes were rubbing on top of the central heating pipes as they were right under the floor boards.
Now the Homeserve plumber has decided to create a U type shape on the pipes to go below the central heating pipes and it looks like this -
The compression corner or the right hand side hot dripped a bit so they came back out, fixed it and then the left hand side hot pipe compression corner started to drip. He tightened it a bit and then went as it had stopped.
Now then next day i noticed a small pin head drip coming from the left hand side hot pipe (red tape) compression corner joint. Wiped it away then today seen another small pin head drip coming from it.
I assume this is bad and still needs fixing (plumber coming back out this aft).
Does this job look ok? are the plastic corners ok?
The pipes run in the ceiling where the solid wall stops as the landing is above so want this not to leak again as the ceiling hole will need repiaring and reskimming and the floor above will have to have the wood florring refitted.
Just a bit concerned.
Yep awaiting there return this aft some time.
Does the U bend of the pipes with those connectors look like the right things for the job? i.e. would you professionals of done this sort of thing?
Thanks again
Feel like footing the bill to get it done proper by a proper pro plumber not a jack of all trades master of none.
How much you reckon it would cost to rectify this so its proper soldered with less joints?
Bargin 🙂
It took about 5 mins for the pipes to empty out, turn the mains tap off, open the taps and the pipes were empty as the plumber was then able to cut the bit of copper pipe section out to make that contraption.
Then refilled in a few mins.
Its just the hot and cold pipes that feed the taps etc.
The under writers pay homeserve £140 per job.
I’m pretty sure you that job took the plumber about 10 mins to do.
The plumbers get loaded with 10+ jobs per day and they must get completed.
Depends what you consider a 'proper' repair. Ideally, I would want to replace the the entire length of damaged pipe back to existing joints with a nicely bent jumper under the CH pipe. I'd also take a critical look at the CH pipes in the areas because copper-on-copper friction often damages both parties to the action. Say three or four hours, mostly spent exposing the work and making good after.
