townfanjon
Subscribed
Dec 19, 2013
8,627
5,854
113
The center of the universe
Guys your thoughts please
I look after a dentists surgery , they have a steraliser ( looks like a mega dishwasher ) that emptys into some 40 mm solvent weld waste , which is simply not up to the job because is can not take the heat ( we think about 90 degrees )
.After speaking to a couple of manufacturers who quoted me the British Standard . No plastic waste pipe will take anywhere near this heat on a prolonged discharge .
Anybody any come up against this before or got any ideas around it .
Thanks in advance
I had something like this with a piece of machinery in an old folks home it might also have been A steriliser. I spoke to LBC and they suggested a waste pipe which is specifically designed for high temperatures mupvc so that's what I used. All seems fine
What`s that Black stuff called ? Be warned though it is a sod to work with as all joints are rubber O ring and you need a tool to cut a groove in the pipe for the O ring to locate in, pretty sure it takes high temps and all sorts of chemicals. Only ever worked with it the once many years ago.
You have a three of options
Steel pipe (press fit or threaded)
Copper (soldered or press fit )
Lab plastic will get a link when I get in from work
Vulcathene
Vulcathene Chemical Drainage Pipe Work | Fittings | Pipekit
Reactions: 2 people
That`s the stuff, only solvent weld wasn`t an option I was given so spent 3 days cutting grooves by hand and assembling the pipe runs in 3 labs.
I've done 4 refurbs in dentists and all specced M UPVC for anything bar general sink waste pipe work
Couldn't say with certainty that they all had sterilisers, but would have thought so
Gents , thanks to all thus far , Shaun many thanks for the link , I had seen that stuff but never knew what the called it .
always use it mate if copper/steel isnt spec for
you need special tools tho
and how to put it all together
[video=youtube;kKMygj4jaZQ]https://www.youtube.com/watch?v=kKMygj4jaZQ[/video]
Yep saw the vid on the link , will start pricing up tomorrow , copper still an option but no idea what would be be cheaper the vulcathene looks expencive .
Don`t throw the tools away at the end and yes think it was expensive mind you I had miles of pipe and sacks of fittings.
Consider terrain waste aswell they do different ranges but even the standard stuff has a higher temperature rating
pity you cant blend it with cold before discharge!
Its funny you should say that , I have only just found out today the steriliser discharges at around 90 degrees so untill its done I am going to advise them to do that . The one problem with this is the last section of the pipe is actualy in a wall cavity, dont ask ...... Builders Pfftttttttttt
