brian_mk
I need to replace a leaking hot water cyclinder.
So far I've contacted about 4 plumbers but none have got back to me, so I'm considering tackling the job myself.
I have bought a drop in replacement cylinder with connections in the exact same positions.
I'm hoping to re-use the existing immersion heater as it has never actually been used.
My question is...
Will there be enough 'give' in the pipework to allow me to remove the old cylinder without cutting pipes?
As far as I can see, it means lifting the hot water outlet pipe up by about 1" to pull it out of the compression fitting to allow the cylinder to be slid to the right to remove the pipes to the coil. The horizontal 22mm section of pipe is about 20" long and the fittings are soldered.
The cold feed to the right has a conex conector at the top of the photo just below a gate valve.
You can't easily get to the elbow fitting at the bottom right of the cyclinder.
I'm hoping there will be enough give in the pipework to pull the cold feed pipe down and out of the compression fitting.
My question is...
