How do I re-pressurize my Alpha CD35C boiler?
View the thread, titled "How do I re-pressurize my Alpha CD35C boiler?" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Hi there,
First of all, apologies for the quality of the attached image - unfortunately the access to the underside of the boiler is quite tight, so I had to stitch a few pictures together to be able to show it all!
As mentioned in the title, I'm wondering how I would go about re-pressuring my boiler? It's an Alpha CD35C if that helps.
From looking up how to re-pressuring a boiler online, it looks like they always open two valves, but on my boiler, I can only see one. I have tried turning the blue valve (labelled 1 in the image below), but opening this doesn't seem to do anything (I can't hear water flowing, the pressure gauge doesn't rise etc.). Do I need to open something else up?
I've labelled 2, 3 + 4 on the attached image as possible things I need to use a screwdriver on to turn, so I'd appreciate advise on what I need to do for this boiler. I could also be totally wrong that the blue valve has anything to do with re-pressuring the boiler, so please let me know if I'm being stupid!
Thanks,
Joe
2 and 1
Make sure the 2 slot is inline with the pipe / flex
Open 1 slowly until you hear water entering
1-1.2 bar close 1 and reset 2 back to where it was
Thanks for the quick response!
Here's a close up shot of 2 (apologies for it being a bit blurry) - it actually doesn't look like this is something a flathead screwdriver can turn, I guess it needs some plyers (or does it need some kind of key)? If I need to use plyers, I guess I just turn it a bit (there's no indiator I can see that shows when its open)?
Looks like the blue lever has snapped off that one so yes on the pliers
Cool, thanks!
Last question - I just tried turning 2 a little with some pliers and water started dripping slowly from the valve, is that to be expected? I just wanted to check as I don't want to turn it more and have water gushing out!
Yes pretty standard if it hasn’t been used for a while should stop once it’s back to original position
Reply to the thread, titled "How do I re-pressurize my Alpha CD35C boiler?" which is posted in Boiler Advice Forum on Plumbers Forums.
joealden,
joealden,
