T
TBServices
Hi guys, been to a property today where a previous GSR has capped off the fire. The landlord wants a new inset fire fitting so I've been, taken out the old fire and inspected the chimney, which is lined and passed the flue flow test.
I don't do many fires and as a result i think it will probably take me a little longer to install than someone with lots of experience in doing them, just want to know what you lot charge so I'm not going in too high (not sure how long to allow for). The flue, hearth and gas supply are all present and in good order, so its literally a case of putting the fire in and testing.
Cheers, Tom.
how old is the liner?
do you need to become a bricklayer/plasterer for the day?
what was the reason for the previous fire being capped?
liners must be guaranteed for 15 years the only way you can check its integrity is to remove it and inspect if in any doubht replace
If its a straight fit, three hours labour. But as above the liner needs to be proved.
I have no idea how old the liner is to be honest, will have to ask the homeowner tomorrow. Looks to be in good nick and the catchment space/opening is structurally sound.
What's the procedure with the liner? Obviously fitting a new liner is a major expense so how do I determine if it needs one? Can't see the landlord going for it tbh.
The old fire was capped due to "cracks in the coals" and the sat GSR advised a new fire to be more cost efficient than replacing. Think the previous guy was trying to create work for himself.
I thought thread would be okay in GSR forum bod?
Thanks for advice guys.
Sent from my iPad using Tapatalk HD
I requested it moved in case people wanted to start putting prices in the thread. It's not good to start quoting prices on the open forum.
Sorry mike, I thought I'd put it in the private gas safe forum.
if the fitting of the fire is straight forward and no building work is required id charge around 60-80 plus parts should take max 1.5hrs. as reguards the liner its for you to decide its condition 🙂
I've quoted £100 over cost of fire, so once extra materials are included, I'd guess I'm about right. The liner looks fairly new, so will discuss with homeowner the potential need to replace.
i would just remove the liner in case its gone pourus , personally i would be looking at covering a days wage as nothing is ever what it seems
but you cant inspect it through out its length without removing it,it might look fine on the end your seeing but be like a colander on top ,dont rely on a flue flow to confirm this,very nieve if you do tb,at the end of the day if it goes wrong your the installer who signed the paperwork,who fitted the appliance,be very careful,because the hse will not except it looked ok and passed a flue flow,for all you know that liners been there for 2 years or 20 they will tell you any old crap to keep the price down
Looks like I'm in for another sleepless night lol.
been there,removed some they look fine,others look fine at the bottom knackered half ways through,at the end of the day mate do whats safe and does not cause sleepless nights:wink_smile:
Can anyone direct me to the guidance on flue liners or explain what my position? Obviously it's been so long since I've even thought about it, I've forgotten.
BS 5440 part 1 page 29
When replacing an appliance connected to a chimney lined with a metallic liner, the existing liner should be replaced unless it is considered that it can continue to operate safely throughout the lifespan of the new appliance.
Under normal operating conditions, a correctly installed metallic liner conforming to BS 715:1989 or BS 715:1993 or BS EN 1856-2 should operate safely for at least the operational lifespan of the appliance, normally 10 years to 15 years.
That's brilliant, thanks mike. God I love this forum.
Why not just fit an electric fire then no problems, and you can sleep nights ?
The tenant uses the fire a lot as he's a bit of a hermit, stays in one room and uses the fire instead of the CH.
does the chimney require a liner? if not and whip the old liner out and make good on the stack
By the looks of the chimney stack outside, it probably does require a liner lol. Obviously pointless removing a liner to then refit it, regardless of condition.
Shame you can't just stick a drain camera down to check the condition
Try to stay away from gas fires myself but found this an interesting quote - you are saying that if you fit a gas fire with a liner then you need to remove the liner to check as the flue flow test wont suffice?
I try to steer clear as well, there's just no money in them.They always take longer than you think. There's nearly always an issue, surrounds not being sealed,under size pipe work etc etc. I just stick to servicing them where I can.
This is why I don't do them generally.
Why do you think i suggested fitting a electric fire ? none of the problems, safe'r to use, & landlord proberly wont pay for what needs doing !.
