Why not just fit an electric fire then no problems, and you can sleep nights ?
The tenant uses the fire a lot as he's a bit of a hermit, stays in one room and uses the fire instead of the CH.
does the chimney require a liner? if not and whip the old liner out and make good on the stack
By the looks of the chimney stack outside, it probably does require a liner lol. Obviously pointless removing a liner to then refit it, regardless of condition.
Shame you can't just stick a drain camera down to check the condition
liners must be guaranteed for 15 years the only way you can check its integrity is to remove it and inspect if in any doubht replace
Try to stay away from gas fires myself but found this an interesting quote - you are saying that if you fit a gas fire with a liner then you need to remove the liner to check as the flue flow test wont suffice?
I try to steer clear as well, there's just no money in them.They always take longer than you think. There's nearly always an issue, surrounds not being sealed,under size pipe work etc etc. I just stick to servicing them where I can.
This is why I don't do them generally.
Why do you think i suggested fitting a electric fire ? none of the problems, safe'r to use, & landlord proberly wont pay for what needs doing !.
